Checking for updates for Components and Wizards in on Nagios XI 2012R2.5 I see several new versions. Clicking on the download links do not initiate a download.
Tested on several workstations in multiple browsers (Firefox and Chrome) with the same results. However, right clicking the links and opening in a new tab work.
Please advise.
XI Update download links not working
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: XI Update download links not working
I can confirm this behavior. EDIT: This is due to cross site restrictions and https/ssl. It is wai if you force https. If you are not using ssl/https let us know.
Yes, our XI servers are using https/ssl.abrist wrote:I can confirm this behavior. EDIT: This is due to cross site restrictions and https/ssl. It is wai if you force https. If you are not using ssl/https let us know.
Yeah, then this is WAI. It is a part of browser cross site restrictions.
Would these WAI restrictions be new to popular browsers? What is a work around?abrist wrote:Yeah, then this is WAI. It is a part of browser cross site restrictions.
For the record, this wasn't an issue back in August when we were at 2012R2.4
Could be. I have the same issues on a 2.4 ssl box as well. Pull up the js console (ctrl-shift-j) and then try to click one of the download links. You should get an error resembling:
[13:02:38.106] Blocked loading mixed active content "http://library.nagios.com/component/search/?searchword=minemap" @ https://<ip>/nagiosxi/admin/Former Nagios employee
Unfortunately I just updated all 10 XI servers, I'll have to wait till another package update is available.
Let us know what you come up with regarding the console.
Confirmed.
Can this browser security feature be temporarily disabled or do know a work around?
[11:31:35.301] Blocked loading mixed active content "http://assets.nagios.com/downloads/nagiosxi/components/massacknowledge.zip" @ https://mydomain.com/nagiosxi/admin/Nagios XI 2024R2.2.1 (8 Servers)
This looks like something new to browsers. See the following page for firefox information and a potential way to temporarily disable the restriction. (FYI - you should be able to right click the links still)
https://blog.mozilla.org/tanvi/2013/04/ ... irefox-23/
