Nagios To Service Now integration
lafargeuser
Need help on Nagios to Service Now Integration.
Re: Nagios To Service Now integration
Looking on Exchange quickly I found the following two plugins you could use:
http://exchange.nagios.org/directory/Pl ... er/details
http://exchange.nagios.org/directory/Tu ... ha/details
These are both community plugins so we won't be able to help too terribly much if they don't work or need tweaking, but we'll do what we can.
lafargeuser
Go here
http://roshamboot.org/main/projects/alp ... tegration/
Not sure what the download link is going to...
Hi all!
You can always download the latest version of the Service-Now integration plugin from: http://roshamboot.org/main/wp-content/u ... cketer.zip
Alternatively you can get it from Nagios Exchange here (as tmcdonald pointed out): http://exchange.nagios.org/directory/Pl ... er/details
I've updated the external download link in the above article to point to the release version instead of the now non-existent beta release. If some one can clip the awesome Mr Miltchev on the ear and have him update his link that would great
Sorry for the confusion!
Thanks for the update! lafargeuser, does this help?
lafargeuser
Using this script to integrate Nagios to SNOW.
While going though the script, I found that The proxy settings are required if your connections to service-now traverse a proxy.
In My environment My Nagios is in our corporate network & SNOW is on Cloud (internet ). Hence, for communication should I need to enable port forwarding at My firewall to the nagios system ?
Or normal proxy seetings will work here ?
The proxy settings in Nagios aren't going to help much with incoming traffic, as things outside of Nagios can't read those proxy settings. So you will probably need to enable port-forwarding, yes.
