Arguments and normal_check_interval parameter
madhudeva
Post by madhudeva »
Hi Team ,
Is there a limit in the number of arguments that you can supply when configuring a service via CMM ( as I can see it allows to setup 8 arguments ) ?
Also , is the normal_check_interval parameter set as default for all services and if so , what is the default value ?
Clive
Reason: You are not posting in the support section, moving this to general XI.
Re: Arguments and normal_check_interval parameter
madhudeva wrote:Hi Team ,
Sort of. Technically you can have up to 32 args, but the CCM page for services allows only 8. However you can sort of cheat this by using quotes to stick multiple things into one arg. Most people never need 8 args. The command definition allows you to specify which and how many args to use, but you still have the restriction in the service definition.
madhudeva wrote:Also , is the normal_check_interval parameter set as default for all services and if so , what is the default value ?
Clive
I don't believe it is. What version of Nagios are you using?
clive.dias
Post by clive.dias »
Thansk for the fix. We use Nagios Xi . But looks like it is a replacement parameter
clive.dias wrote:Thansk for the fix. We use Nagios Xi . But looks like it is a replacement parameter
No problem. Can I close the thread or did I not answer something?
clive.dias
Yes. Please close this request. Thanks for your help
