When I goto update components, I click on the download link, then I'm taken to the subscription page rather than download.
Any ideas why this is happening?
Updating components
Re: Updating components
It may be one of the components that are for paying customers only. If so, and you have an active subscription, you just have to login and download from that link. This happens with quite a few of them.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
@Pilly170
Are you able to access this page? Please, let us know if you have any issues.
@BanditBBS
Thanks, BanditBBS!
@BanditBBS
Thanks, BanditBBS!
Gives me the library.... that right?
Yes, once you log in you should be placed at the customer downloads section.
soon as i click on one of the options, I'm taken to the subscription page
on the right is my username and the logout button so I will assume yes.
You should be able to find the component and update it through Admin > Manage Components now, or are you still having issues reaching the actual download links for the aforementioned components?
