Can we use NNA to analyse traffic of VoIP networks ? Is it possible to obtain QoS reports (jitter, latency, bandwidth etc) ?
NNA (Nagios Network Analyser)
sreinhardt
- -fno-stack-protector
Re: NNA (Nagios Network Analyser)
To some extent yes you can use nna to gather some information on voip networks. However items such as jitter and latency are not currently possible as far as I know. Bandwidth would definitely be included by default though.
Nagios Network Analyzer primarily will show information about connections from host/port to host/port
this information will contain bandwidth for each combination, but for measuring the other elements you mentioned, you may need to pull this information via custom plugin for Nagios XI.
