I am trying to find what user name Nagios uses to check services and what permissions are required.
I have a check that looks for a folder , we replaced the server and copied all folders / files but apparently not all the permissions.
Since the original server is crashed I cant just look at the old permissions.
all other Nagios alerts are working so I am pretty sure it is just permissions that Nagios uses to check+
Here is the error Nagios gives me:
Status Information: Could not construct return packet in NRPE handler check client side (nsclient.log) logs..
How to find what user name Nagios uses to check services
Re: How to find what user name Nagios uses to check services
anyone? is this in the nagios.cfg file?
Usually, nagios and nrpe will use the 'nagios' user.
