When I try to delete a retired host I receive this error:
Could not find a unique id for this host
Host cannot be deleted using this method
So I logged into Nagios Core Config Manager | Monitoring Services | deleted service and went to Hosts and deleted the service. But the deleted host still shows up in the dashboard.
Unable to delete hosts
SinishaEpisource
Re: Unable to delete hosts
Need to delete host entry from configuration file.
Regards,
Sinisha
Regards,
Sinisha
This should be in the XI support section... not ideas, I am moving this. You need to delete everything that is attached to that host, including services, then try deleting the host. If apply configuration fails run the following and share the output here. Wrap the output in code wraps, there is a button in the reply page.
CCM > Tools > Write Configs Tool > Verify.
