Hello Members,
We have 4 Nagios XI instances monitoring 4 different Infrastructure.
We wanted to combine all 4 into 1 Centralized Management system so that all 4 can be managed by the single server.
Can somebody please suggest me if this can be done with Nagios XI?
Multiple Nagios XI with a Central Management System
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Multiple Nagios XI with a Central Management System
We would typically recommend using Nagios Fusion for this, http://www.nagios.com/products/nagiosfusion
That should do the trick for you, if you are looking for something else let us know!
Nagios Fusion will have a centralized dashboard for the views.
Does it also gives a functionality to manage all 4 servers on its own like adding devices working on the configuration etc..
Thanks & Regards,
I2MP Team.
I2MP Team.
sreinhardt
- -fno-stack-protector
It does not allow for central config management without drilling down to each individual server. Unfortunately at this point there is not a released product that will handle this. Fusion will definitely give a centralized dashboard and other views of all your systems.
