Nagios XI on Nagios Core 4.x ?
toper
Post by toper »
Hi Support,
I can see in our Nagios XI installation that Nagios core running version 3.50.
When will Nagios XI updated to use Nagios core 4.x ? - As I understand the Nagios Core 4.x
gives much better performance than Nagios Core 3.x.
Or is it possible to update Nagios Core separately in an NagiosXI installation ?
Nagios XI 2012R2.8c
Linux 2.6.32-431.3.1.el6.x86_64 #1 SMP Fri Dec 13 06:58:20
Peter Calum, TDC Denmark
Peter Calum
Re: Nagios XI on Nagios Core 4.x ?
Post by slansing »
Yes, indeed it does, I would first recommend upgrading to the latest version of XI, as there were already some good changes made. Nagios Core 4 will be released on XI with XI 2014 in the near future, it should be running 4.0.4 on the back end. Do not attempt to upgrade to Core 4 on your own as your version of XI is not going to function properly with it.
toper
Post by toper »
Thank you for answer, I'll upgrade XI to latest version, and waiting for the next release.
br,
Peter
Peter Calum
