check_nagiosstats
WillemDH
check_nagiosstats
Post by WillemDH »
http://exchange.nagios.org/directory/Pl ... 29/details seemed like a nice plugin to get some graphs on the load and amount of service checks, latency etc. Nagios XI however is not listed as compatible.
Is it not compatible? Should I give it a try? I kind of think the server statistics, monitoring engine check statistiscs, monitoring engine performance dashlets are nice, but it seems not possible to get this data in the Graph Explorer. (or is it?)
Any advice on this?
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Re: check_nagiosstats
Post by slansing »
You should be able to get this information by running the Nagios XI Server wizard against localhost, that will get you the same set of information! Otherwise, we can help you with this plugin, which would probably work.
WillemDH
Post by WillemDH »
Sam,
I found the nagiosstats wizard (a bit late to my regrets), which seems to work fine. But I do have some questions. It is possible to get the total service problems and total host problems for a specific hostgroup / servicegroup?
For example I have a hostgroup with all important servers in it, it would be really interesting to have a graph which could visualize the amount of problems for this particular hostgroup. Same for some of my servicegroups.
Grtz
Nagios XI 5.8.1
You can view stats of the localhost only (XI server). I believe the plugin utilizes the "nagiostats". You can view the output by running from the CLI:
/usr/local/nagios/bin/nagiostats
I don't think this will work hostgroups/servicesgroups, remote hosts, etc.
WillemDH
Post by WillemDH »
This thread can be closed. Nagiostats does the trick.
Nagios XI 5.8.1
