Bug: IE does not expand Template Name drop down list
Post by Box293 »
When I am editing a host or a service I use the drop down list "Template Name" to select a template to insert.
In IE, when the drop down list is displayed it does not resize the list window to fit the name of the longest template. In Firefox it does.
I am using 2009R1.1H.
This behaviour occurs with IE 7 and 8.
mmestnik
Re: Bug: IE does not expand Template Name drop down list
Post by mmestnik »
Hmm, I wonder if a balloon would give enough information for the user to visualize where every thing is?
Perhaps we could make this longer, but in the normal case it wastes screen-estate. It's great that large values can be partially obscured most of the time.
File a bug against IE. We may think about solutions.
Post by Box293 »
Post by Box293 »
In IE9 this problem no longer exists.
tonyyarusso
Post by tonyyarusso »
Good to know.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
