Hi all,
I'm using the Network Switch/Router wizard to monitor our routers. How do I get this dormant circuit to not show as critical and just normal (green)
CRITICAL: Interface Serial0/1/0:23 (index 39) is dormant.
Here is the check: check_xi_service_ifoperstatus!XXXXXXX!39!-v 2
- costanza2k1
sreinhardt
- -fno-stack-protector
Re: CRITICAL: Interface Serial0/1/0:23 (index 39) is dormant
I would suggest something like the negate plugin: http://exchange.nagios.org/directory/Do ... in/details
- costanza2k1
Thanks! I'll give it a shot! This can be closed.
