"Apply Configuration" just spins forever
rickwilson7425
Post by rickwilson7425 »
It doesn't matter if I am trying to use the Monitoring Wizard, the Auto-Discovery Wizard or just trying to Apply Configuration from CCM, it just spins and never completes.
Manually writing and verifying configuration in CCM works fine but the wizards don't let you do that.
Re: "Apply Configuration" just spins forever
Post by slansing »
Can you run the following:
./reconfigure_nagios.sh > /tmp/reconfig.txt
And attach reconfig.txt here or in a PM?
rickwilson7425
Here is the output file.
That all looks OK...
Is crond running?
service crond status
rickwilson7425
yep -
[root@dennagxis1 nagiosxi]# service crond status
crond (pid 2248) is running...
abrist
Red Shirt
Post by abrist »
I had similar issues when updating one of my test boxes. Do you have 6 green checks in the upper right corner of the UI?
rickwilson7425
yes, I do.
rickwilson7425
Well, this really sucks.
I just did the upgrade to xi-2014 and now I can't access the web page.
abrist
Red Shirt
Post by abrist »
Do you have maintenance? If so, send an email to [email protected] and we will move to a remote session.
rickwilson7425
No, we are evaluating XI for migration from 3.5 Core at the moment.
