SMS Log
gfesj69
SMS Log
Post by gfesj69 »
Hi! I am using NagiosXI 2012R2.9.
I am having problems with my mobile carrier, and I need to debug the SMS messages.
I need to see the messages that are send to mobile messages (SMS). Is there any log to see it? Any Clues?
Regards
Geraldo
Re: SMS Log
By default Nagios just sends an email to your phone number at some email domain, such as [email protected], so your /var/log/maillog should show outgoing mail being sent, but not content.
gfesj69
Re: SMS Log
Post by gfesj69 »
Thanks, I had check the /var/log/maillog, but i can not find any message to my mobile carrier.
We use SMTP relay to send the messages. Is there any other way to get the logs?
Gerald
Re: SMS Log
If you are not setting any entries in your maillog I would make sure you have the right number set up, and that you do in fact have SMS notifications enabled for that user.
http://assets.nagios.com/downloads/nagi ... _in_XI.pdf
