Nagios XI Upgrade from 2012R2.9 to 2014R1.0 -RAMDISK + MYSQL
mlopez
Post by mlopez »
Current Version: Nagios XI 2012R2.9
Install: Source Installer
Modification:
Utilizing_A_RAM_Disk_In_NagiosXI.pdf
Offloading_MySQL_to_Remote Server.pdf
I was wondering if I would encounter any problems upgrading to Nagios XI 2014R1.0 before I start the installation and if I would need to update my database structure on my offloaded MySQL Server.
- Michael
abrist
Red Shirt
Re: Nagios XI Upgrade from 2012R2.9 to 2014R1.0 -RAMDISK + M
Post by abrist »
There are some sql changes, but as long as your offloaded db was configured per our documentation, the sql should be dumped to the remote db. The settings in nagios.cfg are also respected, so the ramdisk should not be an issue as well.
mlopez
Post by mlopez »
Hi abris,
You may close this thread as I've now upgraded to 2014RC1.1.
Thanks again for your help!
