When I import files, if I un-tick the option Overwrite Database, it still reports that the file was sucessfully imported.
- I go to the Import Config Files tool
I select the file I want to import (this item already exists)
I un-tick the Overwrite Database Option
I click the Import button
When the screen refreshes it reports "1 file(s) imported successfully!"
"folder_path/file_name was NOT imported, already exists!"
And the "1 file(s) imported successfully!" message should correctly report how many it imported, perhaps:
"0/1 file(s) imported successfully!"
