I just cloned a host and it didn't copy the hostgroup that it belonged too to the new hosts. Isn't that something that used to get copied? I have hundreds of hosts to import today and I am going to have to touch each one afterwards to add to the proper hostgroup.
EDIT: I can use bulk modification to modify, so that makes it easier...but still, thought hostgroups were copied in 2012
Bulk host cloning
Bulk host cloning
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Bulk host cloning
As an intermidiary solution, you could try to use the old bulk cloning wizard, if you are able to get it somewhere. I did not try the new bulk host cloning wizard. I'll test it soon.
Nagios XI 5.8.1
https://outsideit.net
Ah-Ha! That checkmark at the bottom of the wizard probably did it. Nevermind, close this thread, pebkac issue!
pebkac=problem exists between keyboard and chair
