problem in traps
hanya.radwan
problem in traps
Post by hanya.radwan »
one server gives the following error:
[07-02-2014 10:31:09] SERVICE ALERT: vadm1;SNMP Traps;WARNING;HARD;3;alarmAdditionalText (OCTETSTR):Node supervision impaired, alarmXCausingInstances (OCTETSTR):imSolaris::vadm1.moip.ericsson.com, alarmXCauseText (OCTETSTR):Host Resource SNMP subagent is down /
[07-02-2014 00:01:55] SERVICE ALERT: vadm1;SNMP Traps;WARNING;HARD;3;alarmAdditionalText (OCTETSTR):Node supervision impaired, alarmXCausingInstances (OCTETSTR):imSolaris::vback1b.moip.ericsson.com, alarmXCauseText (OCTETSTR):MIB-II SNMP subagent is down /
Re: problem in traps
Post by slansing »
Looks to me as if the subagent on those systems is down or unreachable for some reason, I'd talk to the admin who is in charge of them and find out if they can restart it:
http://www.snmp.com/products/hostresource.shtml
hanya.radwan
what is the command for restart subagent and mibs. this server is solaris.
Post by slansing »
No idea, you should talk to your system admin about that as it does not have to do with Nagios. That is what you are monitoring on that system. It might just be the snmp service, it depends on how it was configured. On the note of mibs, you don't restart mibs, mibs are flat files used by snmptt to translate incoming snmp trap data...
