Bandwidth Usage drop down not showing all
CBoekhuis
Post by CBoekhuis »
i noticed that the dropdown menu in reports-->Available Reports-->Bandwidth Usage-->View Report For: (dropdown) is not showing all lines.
I don't know if this started after the changes in mrtg a few versions ago or if i've miss someting.
I generate the config file with /usr/bin/cfgmaker and put the config in /etc/mrtg/conf.d/xxx.xxx.xxx.xxx.cfg.
I'd aspect that the drop down shoud list the new generated hosts in the drop down.
What am i doing wrong?
Regards
Christian Bakker
Re: Bandwidth Usage drop down not showing all
What exact cfgmaker command do you run?
Does it work if you use the Network Switch / Router Wizard instead?
CBoekhuis
Post by CBoekhuis »
/usr/bin/cfgmaker --show-op-down --zero-speed=100000000 --snmp-options=:::::2 --noreversedns [email protected] > 192.168.xxx.xxx.cfg
When using the wizard the drop down shows up , but also generates unneccesary services for each port.
Is there a solution for that?
Post by slansing »
The report should only display hosts/services that are actually in XI, they need to be in the proper configuration format, it will not read any old mrtg config and automatically pull them in.
CBoekhuis
Post by CBoekhuis »
ok. Thanx
