The only problem I have is the data values it is using to monitor most of the items. When I visit the Home > Details > Service Detail page I can see the following
The data is getting there but for example the Memory when I view that graph like below it has all the data.
and you can see the LAST AVG and MAX for each for memory, CPU, Datastore usage etc...
But it keeps using the "Max" field data. So the graph above is monitoring if I ever change the amount of RAM in the host instead of how much of the ram is being used.
But the data is there I'm just not sure where I can find this code / scripts / config to go manipulate it to fix it.
Any chance someone can point me in the right direction?
Searched the forums all over was surprised I couldn't find anyone else mention this.
