SMS notifications with Nagios XI
jimhoffmann
Post by jimhoffmann »
I have seen several posts referring to the MultiTech iSMS device to use for sending notifications via SMS. I purchased one of these devices only to learn that it requires a 2G GSM network. There is only one carrier in my area that has a 2G network and signal strength is not going to be sufficient in my building. Is anyone using a similar device that works on a 3G network?
- Bill
BanditBBS
Re: SMS notifications with Nagios XI
Post by BanditBBS »
Are you in the US? AT&T and T-Mobile sims should work fine. At current job I have 2 AT&T ones in it and works fine with included antennas. At my old job we had to use a booster to get out of the datacenter.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
jimhoffmann
Yes, I'm in Bloomington, MN. I brought it to an AT&T store and they put in an active SIM and it had no signal. Is there something more we should have configured?
Thanks.
Post by slansing »
Could the device be at fault? We don't directly support the device itself, simply the pairing of it and XI, if it's having signal issues I'd definitely give multitech a call / post and see if they've seen this problem before. We will do what we can!
BanditBBS
Post by BanditBBS »
billslott wrote:Yes, I'm in Bloomington, MN. I brought it to an AT&T store and they put in an active SIM and it had no signal. Is there something more we should have configured?
Thanks.
Which device is this, the 1, 4 or 8 port? If the 4 or 8, you had an antenna screwed in, right?
You played around with the sim, wiggling it around? LOL
Also, it needs to be a GSM sim, so 3G should work fine but not 4G.
Thanks, BanditBBS!
krobertson71
Post by krobertson71 »
Stupid question.....
But bandit posted here so I should be safe.. anyway..
What about CDMA Verizon device? Can that be set up to work with Nagios XI or does it have to be GSM?
BanditBBS
Post by BanditBBS »
krobertson71 wrote:Stupid question.....
You're so mean! And no, not the multitech devices, they are GSM only.
krobertson71
jimhoffmann
This is the 1 port device and yes, I did have the antenna attached. The AT&T support person supplied the active SIM. I didn't ask if it was 3G or 4G so that might be the issue if it was 4G. I am in contact with Multi Tech support also. I will see what they say.
Thanks!
