Duration field is showing (???) symbols
Apurv
Post by Apurv »
Hello All,
I am facing an issue since yesterday. All of a sudden the "Duration" field in nagios web interface has started showing "???" symbol. I have also attached a screenshot of the same with this thread. As I am a newbie to nagios I would really appreciate guidance/assistance on how to get this resolved. Can someone please help me out?
Thanks in advance!
Duration field showing "???" symbol
Re: Duration field is showing (???) symbols
You should be able to run
grep "date.timezone" /etc/php.ini
php -r 'echo date("D M j G:i:s T Y")."\n";'
date
to get a good idea if your time settings are matching up or not. Go ahead and run that for starters and show us the output.
Apurv
Post by Apurv »
Thank you for replying...
Ye! ur correct... actually my date settings were not proper,but I had realized this and changed the timezone and date to the correct one. Then restarted the nagios service and http service. After that I waited almost 2-3 hours but the duration field was still showing the "???" sign. Hence I then submitted the ticket.
Is there anything else that u can suggest me to get this issue resolved??
Awaiting ur reply!!
abrist
Red Shirt
Post by abrist »
What version of core are you running?
Have the checks associated with those ??? durations even been run yet? If so, are they running as expected?
Apurv
Post by Apurv »
I am running nagios core 4.03. Once I changed the time settings on my server,I manually re-scheduled the checks for all services of each n every host. Still the "???" were appearing on the WEB interface.
Are there actually check commands specified in the definitions for these services?
Apurv
Post by Apurv »
Yep!! There are command definitions for these services.
It is like they have never ran.
It is possible to share the object configuration for these?
Apurv
Post by Apurv »
scottwilkerson wrote:It is like they have never ran.
This post can be marked as "Resolved".
