Send Notification when Alert Acknowledged
costanza2k1
Post by costanza2k1 »
I swear I saw a check box to send an email or SMS when an alert gets acknowledged...am I missing something?
Re: Send Notification when Alert Acknowledged
Post by slansing »
Not sure where that would be set, it's not available in the standard UI besides typical acknowledgement options, or as an option through Core. Maybe a custom component?
zaji_nms
Post by zaji_nms »
Dear Expert
Sound great, in this case (if feature got added by NagiosXI), our customer will not get false link down message.
FYI, some time there is high delay in our network due to path change or DDoS attack, which generating many false alerts but our Customer will not receive False Alerts as our Monitoring Team will not acknowledge these false alerts.....if feature got added
Regards
Zajil NMS
The contacts are notified when the problem is acknowledged. Is it possible that you were looking at the "Mass Acknowledge" component?
When you are in the process of acknowledging a problem there is a check box to "Send Notification:"
costanza2k1
scottwilkerson wrote:When you are in the process of acknowledging a problem there is a check box to "Send Notification:"
Ok thanks this will work!
