Technical Skill Required to Develop Customized Nagios Core
wipro_kvb
Post by wipro_kvb »
we are using Nagios core in our organisation and I would like to customise the NAgios core based on our organisation needs.
Can you please let us know what kind of skills is required likePHP/RDBMS/ Shell Scripting / C/ C++.
Regards.... Subramanian
Re: Technical Skill Required to Develop Customized Nagios Co
The main engine is written in C, with newer versions having a PHP frontend.
wipro_kvb
Post by wipro_kvb »
Thanks for your reply ...
for customizing the Nagios based on our organization requires C and PHP skills.. .. Correct me If I am worng ?
That's really all you should need language-wise (I am lumping HTML/CSS/JS into the PHP category).
