Is it possible to run Nagios client under an account with less privileges than Local System? Is there any documentation about it?
Tight Nagios Client security on Windows
Re: Tight Nagios Client security on Windows
Is this in regards to NSClient, NCPA, or another agent? The answer will likely depend on what agent, or method you are using.
It would be with NCPA
NCPA may not need it, but you would have to roll your own account with the necessary access (disks, memory, perf counters, proc, etc)
