Monitor Dell Compellent Storage
igsadmin
Post by igsadmin »
Hi guys,
Is there anyone got experience to monitor Dell Compellent Storage in Nagios XI?
I can't find any plugins support by Dell Compellent..
Hope someone expert can advise.
Thanks.
jkinning
Re: Monitor Dell Compellent Storage
Post by jkinning »
I too would like to know how others are monitoring Compellent storage.
Post by slansing »
I don't see any direct plugins either, does it support SNMP? That would be a viable solution in most cases.
igsadmin
Post by igsadmin »
slansing wrote:I don't see any direct plugins either, does it support SNMP? That would be a viable solution in most cases.
Hi, the storage can setup snmp...
but how can we manage it from Nagios XI without any plugins?
We have an SNMP wizard that will handle all the SNMP setup. You can find our wizards under Configure -> Monitoring Wizards.
igsadmin
Post by igsadmin »
tmcdonald wrote:We have an SNMP wizard that will handle all the SNMP setup. You can find our wizards under Configure -> Monitoring Wizards.
Hi, but the Dell Compellent Storage is not in the Monitoring Wizards...
Can advise?
Post by slansing »
Yes, as mentioned, you can use the SNMP wizard. You don't need to look for a wizard that is named specifically after a device which you wish to check via SNMP. Give the SNMP wizard a shot, you could also walk the device with the SNMP Walk wizard, and monitor it from there too...
igsadmin
Post by igsadmin »
slansing wrote:Yes, as mentioned, you can use the SNMP wizard. You don't need to look for a wizard that is named specifically after a device which you wish to check via SNMP. Give the SNMP wizard a shot, you could also walk the device with the SNMP Walk wizard, and monitor it from there too...
I need to know the OID, am I right?
But with this setup, is the graph able to generate?
If you know the OID you can use it directly in the plain SNMP Wizard, otherwise the SNMP Walk Wizard will list all the available OIDs on the device.
As for graphing, check_snmp can usually parse out some useful strings from the SNMP output.
