Importing Nagios Core into NagiosXI
eng.s.akramawi
Post by eng.s.akramawi »
I am working on Nagios core, but recently I have installed NagiosXI.
I couldn't import the config file of the Nagios core into XI, can you please help me adding the hosts to the NagiosXI quickly.
abrist
Red Shirt
Re: Importing Nagios Core into NagiosXI
Post by abrist »
How did the import fail?
Did you follow the prep doc and then the import doc?
http://assets.nagios.com/downloads/nagi ... p-Tool.pdf
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
eng.s.akramawi
After importing,
All hosts status in the Host details are Pending.
How to fix this issue?
Also this error appeared,
ERROR: Bad JSON format!
abrist
Red Shirt
Post by abrist »
What version of XI are you running?
eng.s.akramawi
Nagios XI 2014R2.5
abrist
Red Shirt
Post by abrist »
If they stay as "pending" they are either missing a check command, or are never getting scheduled, run, or inserted into tthe db. As many things can cause this, it may be best to open a ticket (if you are a paying client) by emailing [email protected].
