When I run the full install, i have this error:
Nagios Log Server Installation
DATE: Wed Feb 18 10:46:01 CET 2015
DISTRO INFO:
CentOS
6.2
x86_64
Running 'setup_local_syslog'...
cp: cannot stat `nagioslogserver/logserver.syslog': No such file or directory
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'setup_local_syslog'
the file logserver.syslog not exits..
any sugestion?
Error Fullinstall
Re: Error Fullinstall
Can you post the whole "install.log"? It should be in the "/tmp/nagioslogserver" directory.
On this Centos 6.2 system, are you running rsyslog?
and can you show us the output of these commands:
ls -l /etc/rsyslog.conf
ls -ld /etc/rsyslog.d/
ls -l /etc/rsyslog.d/
install.log:
DATE: Wed Feb 18 17:03:33 CET 2015
DISTRO INFO:
CentOS
6.2
x86_64
INSTALLATION ERROR!
-rw-r--r--. 1 root root 2875 Dec 10 11:05 /etc/rsyslog.conf
drwxr-xr-x. 2 root root 4096 Jan 30 12:30 /etc/rsyslog.d/
total 4
-rw-r--r--. 1 root root 539 Jan 30 12:30 nagioslogserver.conf
install.log:
DISTRO INFO:
CentOS
6.2
x86_64
INSTALLATION ERROR!
total 4
OK, it looks as if you already have the nagioslogserver.conf file copied from an earlier install.
Can you show us the output of the following command: (assuming that you untar'd the nagioslogserver-*-tar.gz file into /tmp)
Again, it would be helpful if you include the install.log from the /tmp/nagioslogserver directory,
ls -l /tmp/nagioslogserver
total 1360
-rwxr-xr-x. 1 root root 5375 Jan 30 12:44 fullinstall
-rw-r--r--. 1 root root 1340903 Dec 15 19:13 get-pip.py
-rw-r--r--. 1 root root 589 Feb 18 17:03 install.log
-rwxr-xr-x. 1 root root 15290 Dec 15 19:13 libinstall.sh
drwxr-xr-x. 2 root root 4096 Dec 15 19:13 licenses
drwxr-xr-x. 2 root root 4096 Dec 15 19:13 mibs
drwxr-xr-x. 3 root root 4096 Dec 15 19:13 nagioslogserver
drwxr-xr-x. 2 root root 4096 Dec 15 19:14 sourceguardian
drwxr-xr-x. 5 root root 4096 Dec 15 19:13 subcomponents
total 1360
The dates on these files look like they have been modified...
Please run the following:
cd /tmp
rm -rf nagioslogserver*
wget http://assets.nagios.com/downloads/nagios-log-server/nagioslogserver-latest.tar.gz
tar xzf nagioslogserver-*.tar.gz
cd /tmp/nagioslogserver
./fullinstall
Great. It's solved.
thanks a lot.
Regards.
Great. It's solved.
thanks a lot.
Regards.
