So I am created a generic auto-login account to deploy to the masses at my company. I was wondering if it it possible to redirect the default login page to the Views page ?
That way I can define URL's of other monitoring systems point to nagvis etc. from the "Views" page. I tried to point the default page to a URL but it just shows views page inside the original column.
My goal is to have the views page autolaunch at full size if possible. That way I can dictate all views myself that appear in the left hand column. Does this make sense ?
Read only login view
Re: Read only login view
This document might help you with changing the default home page.
http://assets.nagios.com/downloads/nagi ... g-Page.pdf
It look like that doc is for older version ?
I thought this was a bug at first - however the behavior is expected. The URL you enter in the 'Custom URL' field will be displayed when you click 'home'.
If there is a specific view that you would like your users to see, navigate to that view and click the 'popout' icon in the top-right side of the GUI.
Once you have done that, copy the URL starting with '/nagiosxi/'. Paste the copied URL under the previously mentioned 'Custom URL' field (Admin > Manage Components > Home Page Modification).
For example, my test URL was
Please let us know if that helps.
/nagiosxi/includes/components/xicore/status.php?show=services&hoststatustypes=2&servicestatustypes=28&serviceattr=10Re: Read only login view
So if I make the "View" my default page I get the attached results. I just need a way for the "view" page to open full and not within the condensed box.
I think the issue here is that the "views" page loads the whole page - all frames. Each individual view can be set as the home page (by using the url from right clicking the view and opening in a new tab), but the rotation cannot.
I was able to point the auto login account to the nagvis url. Boss is happy so far .... Thanks for the tips
Should we leave this open for a bit or are we clear to close it up?
please close thank you
