error message template - beginner
kristine
Post by kristine »
Dear Forum,
First thanks for all the volunteer helpers.
This ist my first try with nagios and :qI am just learning and following a book . I am trying to understand creating your own templates .
I created this one template (one file)
name host-template-generic
register 0
max_check_attempts 3
check_period 24x7
check_interval 5
retry_interval 2
notification_options d,u,r
name host-template-windows
register 0
use host-template-generic
contact_groups admins
name host-template-linux
register 0
I am getting this error message from nagios:
Error: Template 'host-template-generic' specified in host definition could not be not found (config file '/etc/nagios/example/templates/hosts.cfg', starting on line 34)
How is it possible that nagios can not see the host-template-generic ? The name is correct. What do I not understand or overlook?
Many thanks for helping me in advance.
kristine
jdalrymple
Skynet Drone
Re: error message template - beginner
Post by jdalrymple »
You are showing 3 host templates here, and they look good and verify well. The problem is likely that this file is not being processed, and you have a host elsewhere referencing these templates.
Make sure that you have a line in your nagios.cfg that reads something like:
cfg_file=/etc/nagios/myfile.cfg
It needs to point to the file where you're defining these templates.
kristine
Post by kristine »
Thank you for your fast response.
I have the whole directory pointing to cfg_dir=/etc/nagios/example
I thought this would be enough?
I created now 3 different templates and got the same error message.
My host files look like that
use host-template-linux
host_name firewall.localdomain
alias Firewall (internes Bein)
address 192.168.178.11
The name of the host files and template files ARE THE SAME but in a differnet directory.Could this be a problem ?
many thanks. kristine
jdalrymple
Skynet Drone
That should work fine, and it actually even does on my test machine.
Can you post the output of the following:
/sbin/nagios -v /etc/nagios/nagios.cfg
Note your paths MAY not be the same as mine and you may have to adjust your command to accommodate that.
kristine
Post by kristine »
Thank you again..this is my output:
(Information : Suse 13.1 System, Nagios installed through rpm)
Nagios Core 3.5.1
Last Modified: 08-30-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/etc/nagios/example'...
Processing object config directory '/etc/nagios/example/hostgroups'...
Processing object config directory '/etc/nagios/example/contacts'...
Processing object config directory '/etc/nagios/example/commands'...
Processing object config file '/etc/nagios/example/commands/host.cfg'...
Processing object config file '/etc/nagios/example/commands/notifications.cfg'...
Processing object config directory '/etc/nagios/example/contactgroups'...
Processing object config directory '/etc/nagios/example/hosts'...
Processing object config file '/etc/nagios/example/hosts/linux.cfg'...
Processing object config file '/etc/nagios/example/hosts/printer.cfg'...
Processing object config file '/etc/nagios/example/hosts/windows.cfg'...
Processing object config file '/etc/nagios/example/timeperiods.cfg'...
Processing object config directory '/etc/nagios/example/templates'...
Processing object config file '/etc/nagios/example/templates/linux.cfg'...
Processing object config file '/etc/nagios/example/templates/hosts.cfg'...
Processing object config file '/etc/nagios/example/templates/printer.cfg'...
Processing object config file '/etc/nagios/example/templates/windows.cfg'...
Processing object config file '/etc/nagios/example/templates/contacts.cfg'...
Processing object config directory '/etc/nagios/example/services'...
Processing object config file '/etc/nagios/example/contacts.cfg'...
Error: Template 'host-template-generic' specified in host definition could not be not found (config file '/etc/nagios/example/templates/windows.cfg', starting on line 1)
kristine
Post by kristine »
this is how my templates folder looks like . hosts= my generic template for hosts.
Thanks again for any help.
Kristine
Post by Box293 »
Can you provide us with the template file? Not a copy of the contents of the file but the actual file?
I'm going to throw a dart at the dartboard guess that perhaps the files are in a DOS format?
http://www.cyberciti.biz/faq/howto-unix ... xt-format/
kristine
Post by kristine »
Thank you.
Here is my template file created with vi and the ending cfg.
Regards Kristine
hosts.cfg
My template file
(417 Bytes) Downloaded 341 times
jdalrymple
Skynet Drone
The problem is your comments.
From http://nagios.sourceforge.net/docs/3_0/ ... tions.html
When creating and/or editing configuration files, keep the following in mind:
Lines that start with a '#' character are taken to be comments and are not processed
Directive names are case-sensitive
Characters that appear after a semicolon (;) in configuration lines are treated as comments and are not processed
kristine
Post by kristine »
:D
Jipeeh!! Yes !!!!!!!!!!
Thanks to you and the forum !
Regards Kristine
Ps.:Thread closed
