Status information UNKNOWN
ziedmahjoub
Post by ziedmahjoub »
Hi ,
i'm monitoring a network and i got a machine with some unknown status and message information that i didn't understand :
Service                 Status              Status Information
CPU Load             Unknown          NSClient - ERROR : Could not get data for 5 perhaps we don't collect data this far back ?
Memory Usage      Unknown          NSClient - ERROR : failed to get PDH Value
Uptime                 Unknown          NSClient - ERROR : Couldn't get Value
i just want to know what this messages means
thanks
Re: Status information UNKNOWN
What OS+version and NSClient+version are you using?
ziedmahjoub
tmcdonald wrote:What OS+version and NSClient+version are you using?
the client OS is windows XP and the NSClient++ is 0.3.9 the stable one
jdalrymple
Skynet Drone
Post by jdalrymple »
ziedmahjoub
Can we see your service definitions for the services that are failing?
thanks
Post by Box293 »
It sounds like the performance counters on the Windows box need fixing.
From the windows box run:
lodctr /R
After that restart the NSClient++ service.
ziedmahjoub
jdalrymple wrote:ziedmahjoub
thanks
i'm using these service definitions for other users in the same network and its working fine so i think the problem is from his PC , so i want to know what these errors means .
	use			generic-service
	host_name		Soteb_Nizar,Tesco_Teheni
	service_description	Uptime
	check_command		check_nt!12494!UPTIME
	use			generic-service
	service_description	CPU Load
	check_command		check_nt!12494!CPULOAD!-l 5,80,90
	use			generic-service
	service_description	Memory Usage
	check_command		check_nt!12494!MEMUSE!-w 80 -c 90
also i got another UNKNOWN STATUS : Free disk space : Invalid drive
look at the attachment
thanks
unknown status
unknown status
jdalrymple
Skynet Drone
Did you perform the troubleshooting task Box293 suggested?
lodctr /R
Could you post the service check for your c:\ drive space check and also your nsi.ini file from the NSClient++ folder on the windows PC?
ziedmahjoub
jdalrymple wrote:Did you perform the troubleshooting task Box293 suggested?
lodctr /R
no i didn't yet
Can you please answer tgriep's question? In order to help you better we need you to answer all questions, not just the first one.
