Default Flap Detection threshold
What is the default flap detection threshold? In other words, if I turn on Flap detection enabled on a service and I don't add low flap or high flap thresholds, what are the default low flap and high flap threshold?
Re: Default Flap Detection threshold
According to the service definitions, if you set it to 0 (or, I am assuming, leave it blank) then the system-wide defaults will be used. They are set in nagios.cfg and are called:
high_host_flap_threshold=20.0
low_host_flap_threshold=5.0
Thanks. Please feel free to close.
