nagmoto
Posts: 195 Joined: Fri Jan 09, 2015 8:05 am
Post
by nagmoto » Fri Apr 10, 2015 10:27 am
Hi
This is a 4.1rc running on CentOS7.1, I found switching use_syslog's value from 1 to 0 and restart nagios, doesn't stop the logging into /var/log/message.
Can you confirm this is a bug ? or Just my mistake somewhere.
[root@nagios1 ~]# grep use_syslog /etc/nagios/nagios.cfg
#use_syslog=1
use_syslog=0
[root@nagios1 ~]#
Posts: 9190 Joined: Thu Oct 30, 2014 9:02 am
Post
by tgriep » Fri Apr 10, 2015 11:21 am
Can you login to the Nagios server in a shell and run the following and post the output?
Be sure to check out our
Knowledgebase for helpful articles and solutions!
nagmoto
Post
by nagmoto » Sat Apr 11, 2015 10:49 pm
A few changes since my last post.
nagios1 now is under pacemaker+corosync control, the rrd and status data are in /data2 filesystem which on top of /dev/drbd0. /data2 will be failover between nagios1 and nagios2.
private info masked with xxx
[root@nagios1 ~]# cat /etc/redhat-release
CentOS Linux release 7.1.1503 (Core)
[root@nagios1 ~]# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 204876 4824 ? Ss 20:28 0:03 /usr/lib/systemd/systemd --switched-root --system --deserialize 24
root 2 0.0 0.0 0 0 ? S 20:28 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 20:28 0:05 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/0:0H]
root 8 0.0 0.0 0 0 ? S 20:28 0:00 [migration/0]
root 9 0.0 0.0 0 0 ? S 20:28 0:00 [rcu_bh]
root 10 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/0]
root 11 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/1]
root 12 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/2]
root 13 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/3]
root 14 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/4]
root 15 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/5]
root 16 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/6]
root 17 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/7]
root 18 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/8]
root 19 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/9]
root 20 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/10]
root 21 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/11]
root 22 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/12]
root 23 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/13]
root 24 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/14]
root 25 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/15]
root 26 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/16]
root 27 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/17]
root 28 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/18]
root 29 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/19]
root 30 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/20]
root 31 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/21]
root 32 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/22]
root 33 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/23]
root 34 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/24]
root 35 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/25]
root 36 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/26]
root 37 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/27]
root 38 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/28]
root 39 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/29]
root 40 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/30]
root 41 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/31]
root 42 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/32]
root 43 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/33]
root 44 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/34]
root 45 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/35]
root 46 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/36]
root 47 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/37]
root 48 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/38]
root 49 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/39]
root 50 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/40]
root 51 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/41]
root 52 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/42]
root 53 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/43]
root 54 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/44]
root 55 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/45]
root 56 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/46]
root 57 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/47]
root 58 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/48]
root 59 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/49]
root 60 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/50]
root 61 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/51]
root 62 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/52]
root 63 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/53]
root 64 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/54]
root 65 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/55]
root 66 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/56]
root 67 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/57]
root 68 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/58]
root 69 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/59]
root 70 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/60]
root 71 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/61]
root 72 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/62]
root 73 0.0 0.0 0 0 ? S 20:28 0:00 [rcuob/63]
root 74 0.6 0.0 0 0 ? S 20:28 1:09 [rcu_sched]
root 75 0.1 0.0 0 0 ? S 20:28 0:19 [rcuos/0]
root 76 0.1 0.0 0 0 ? S 20:28 0:12 [rcuos/1]
root 77 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/2]
root 78 0.0 0.0 0 0 ? S 20:28 0:05 [rcuos/3]
root 79 0.0 0.0 0 0 ? S 20:28 0:09 [rcuos/4]
root 80 0.0 0.0 0 0 ? S 20:28 0:11 [rcuos/5]
root 81 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/6]
root 82 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/7]
root 83 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/8]
root 84 0.0 0.0 0 0 ? S 20:28 0:09 [rcuos/9]
root 85 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/10]
root 86 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/11]
root 87 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/12]
root 88 0.0 0.0 0 0 ? S 20:28 0:10 [rcuos/13]
root 89 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/14]
root 90 0.0 0.0 0 0 ? S 20:28 0:06 [rcuos/15]
root 91 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/16]
root 92 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/17]
root 93 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/18]
root 94 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/19]
root 95 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/20]
root 96 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/21]
root 97 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/22]
root 98 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/23]
root 99 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/24]
root 100 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/25]
root 101 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/26]
root 102 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/27]
root 103 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/28]
root 104 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/29]
root 105 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/30]
root 106 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/31]
root 107 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/32]
root 108 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/33]
root 109 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/34]
root 110 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/35]
root 111 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/36]
root 112 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/37]
root 113 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/38]
root 114 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/39]
root 115 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/40]
root 116 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/41]
root 117 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/42]
root 118 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/43]
root 119 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/44]
root 120 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/45]
root 121 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/46]
root 122 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/47]
root 123 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/48]
root 124 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/49]
root 125 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/50]
root 126 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/51]
root 127 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/52]
root 128 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/53]
root 129 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/54]
root 130 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/55]
root 131 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/56]
root 132 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/57]
root 133 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/58]
root 134 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/59]
root 135 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/60]
root 136 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/61]
root 137 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/62]
root 138 0.0 0.0 0 0 ? S 20:28 0:00 [rcuos/63]
root 139 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/0]
root 140 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/1]
root 141 0.0 0.0 0 0 ? S 20:28 0:02 [migration/1]
root 142 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/1]
root 144 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/1:0H]
root 145 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/2]
root 146 0.0 0.0 0 0 ? S 20:28 0:00 [migration/2]
root 147 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/2]
root 149 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/2:0H]
root 150 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/3]
root 151 0.0 0.0 0 0 ? S 20:28 0:00 [migration/3]
root 152 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/3]
root 154 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/3:0H]
root 155 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/4]
root 156 0.0 0.0 0 0 ? S 20:28 0:00 [migration/4]
root 157 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/4]
root 159 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/4:0H]
root 160 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/5]
root 161 0.0 0.0 0 0 ? S 20:28 0:01 [migration/5]
root 162 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/5]
root 164 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/5:0H]
root 165 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/6]
root 166 0.0 0.0 0 0 ? S 20:28 0:00 [migration/6]
root 167 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/6]
root 169 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/6:0H]
root 170 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/7]
root 171 0.0 0.0 0 0 ? S 20:28 0:00 [migration/7]
root 172 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/7]
root 174 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/7:0H]
root 175 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/8]
root 176 0.0 0.0 0 0 ? S 20:28 0:00 [migration/8]
root 177 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/8]
root 179 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/8:0H]
root 180 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/9]
root 181 0.0 0.0 0 0 ? S 20:28 0:02 [migration/9]
root 182 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/9]
root 183 0.0 0.0 0 0 ? S 20:28 0:01 [kworker/9:0]
root 184 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/9:0H]
root 185 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/10]
root 186 0.0 0.0 0 0 ? S 20:28 0:00 [migration/10]
root 187 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/10]
root 189 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/10:0H]
root 190 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/11]
root 191 0.0 0.0 0 0 ? S 20:28 0:00 [migration/11]
root 192 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/11]
root 194 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/11:0H]
root 195 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/12]
root 196 0.0 0.0 0 0 ? S 20:28 0:00 [migration/12]
root 197 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/12]
root 199 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/12:0H]
root 200 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/13]
root 201 0.0 0.0 0 0 ? S 20:28 0:02 [migration/13]
root 202 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/13]
root 203 0.0 0.0 0 0 ? S 20:28 0:02 [kworker/13:0]
root 204 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/13:0H]
root 205 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/14]
root 206 0.0 0.0 0 0 ? S 20:28 0:00 [migration/14]
root 207 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/14]
root 209 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/14:0H]
root 210 0.0 0.0 0 0 ? S 20:28 0:00 [watchdog/15]
root 211 0.0 0.0 0 0 ? S 20:28 0:00 [migration/15]
root 212 0.0 0.0 0 0 ? S 20:28 0:00 [ksoftirqd/15]
root 214 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/15:0H]
root 215 0.0 0.0 0 0 ? S< 20:28 0:00 [khelper]
root 216 0.0 0.0 0 0 ? S 20:28 0:00 [kdevtmpfs]
root 217 0.0 0.0 0 0 ? S< 20:28 0:00 [netns]
root 218 0.0 0.0 0 0 ? S< 20:28 0:00 [writeback]
root 219 0.0 0.0 0 0 ? S< 20:28 0:00 [kintegrityd]
root 220 0.0 0.0 0 0 ? S< 20:28 0:00 [bioset]
root 221 0.0 0.0 0 0 ? S< 20:28 0:00 [kblockd]
root 222 0.0 0.0 0 0 ? S 20:28 0:00 [khubd]
root 223 0.0 0.0 0 0 ? S< 20:28 0:00 [md]
root 224 0.0 0.0 0 0 ? S 20:28 0:00 [kworker/3:1]
root 226 0.0 0.0 0 0 ? S 20:28 0:00 [khungtaskd]
root 227 0.0 0.0 0 0 ? S 20:28 0:00 [kswapd0]
root 228 0.0 0.0 0 0 ? S 20:28 0:00 [kswapd1]
root 229 0.0 0.0 0 0 ? S 20:28 0:00 [kswapd2]
root 230 0.0 0.0 0 0 ? S 20:28 0:00 [kswapd3]
root 231 0.0 0.0 0 0 ? SN 20:28 0:00 [ksmd]
root 232 0.0 0.0 0 0 ? SN 20:28 0:00 [khugepaged]
root 233 0.0 0.0 0 0 ? S 20:28 0:00 [fsnotify_mark]
root 234 0.0 0.0 0 0 ? S< 20:28 0:00 [crypto]
root 243 0.0 0.0 0 0 ? S< 20:28 0:00 [kthrotld]
root 246 0.0 0.0 0 0 ? S< 20:28 0:00 [kmpath_rdacd]
root 248 0.0 0.0 0 0 ? S< 20:28 0:00 [kpsmoused]
root 269 0.0 0.0 0 0 ? S< 20:28 0:00 [deferwq]
root 290 0.0 0.0 0 0 ? S 20:28 0:01 [kworker/11:1]
root 294 0.0 0.0 0 0 ? S 20:28 0:00 [kauditd]
root 365 0.0 0.0 0 0 ? S 20:28 0:00 [kworker/7:1]
apache 367 0.0 0.0 324116 8324 ? S 23:13 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 368 0.0 0.0 324124 8124 ? S 23:13 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 369 0.0 0.0 324100 8308 ? S 23:13 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 371 0.0 0.0 324100 8224 ? S 23:13 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
root 504 0.0 0.0 0 0 ? S< 20:28 0:00 [ata_sff]
root 505 0.0 0.0 0 0 ? S 20:28 0:00 [scsi_eh_0]
root 506 0.0 0.0 0 0 ? S< 20:28 0:00 [scsi_tmf_0]
root 507 0.0 0.0 0 0 ? S 20:28 0:00 [scsi_eh_1]
root 508 0.0 0.0 0 0 ? S< 20:28 0:00 [scsi_tmf_1]
root 510 0.0 0.0 0 0 ? S< 20:28 0:00 [mpt_poll_0]
root 511 0.0 0.0 0 0 ? S< 20:28 0:00 [mpt/0]
root 518 0.0 0.0 0 0 ? S 20:28 0:00 [scsi_eh_2]
root 519 0.0 0.0 0 0 ? S< 20:28 0:00 [scsi_tmf_2]
root 520 0.1 0.0 0 0 ? S 20:28 0:13 [kworker/u129:3]
root 521 0.0 0.0 0 0 ? S< 20:28 0:00 [ttm_swap]
root 524 0.0 0.0 0 0 ? S 20:28 0:00 [kworker/15:1]
root 619 0.0 0.0 0 0 ? S 20:28 0:00 [kworker/15:2]
root 620 0.0 0.0 0 0 ? R 20:28 0:00 [kworker/12:2]
root 621 0.0 0.0 0 0 ? S< 20:28 0:00 [kdmflush]
root 622 0.0 0.0 0 0 ? S< 20:28 0:00 [bioset]
root 631 0.0 0.0 0 0 ? S< 20:28 0:00 [kdmflush]
root 632 0.0 0.0 0 0 ? S< 20:28 0:00 [bioset]
root 650 0.0 0.0 0 0 ? S< 20:28 0:00 [xfsalloc]
root 651 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs_mru_cache]
root 652 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-buf/dm-1]
root 653 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-data/dm-1]
root 654 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-conv/dm-1]
root 655 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-cil/dm-1]
root 656 0.0 0.0 0 0 ? S< 20:28 0:01 [kworker/0:1H]
root 657 0.1 0.0 0 0 ? S 20:28 0:12 [xfsaild/dm-1]
root 704 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/10:1H]
root 705 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/11:1H]
root 706 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/8:1H]
root 707 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/9:1H]
root 715 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/5:1H]
root 716 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/6:1H]
root 717 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/7:1H]
root 718 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/4:1H]
root 728 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/13:1H]
root 743 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/12:1H]
root 744 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/14:1H]
root 745 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/15:1H]
root 766 0.0 0.0 59400 14980 ? Ss 20:28 0:04 /usr/lib/systemd/systemd-journald
root 777 0.0 0.0 178224 1148 ? Ss 20:28 0:00 /usr/sbin/lvmetad -f
root 786 0.0 0.0 42920 2184 ? Ss 20:28 0:00 /usr/lib/systemd/systemd-udevd
root 791 0.0 0.0 0 0 ? S< 20:28 0:00 [rpciod]
root 896 0.0 0.0 0 0 ? S< 20:28 0:00 [kdmflush]
root 897 0.0 0.0 0 0 ? S< 20:28 0:00 [bioset]
root 925 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-buf/sda1]
root 926 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-data/sda1]
root 927 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-conv/sda1]
root 928 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-cil/sda1]
root 930 0.0 0.0 0 0 ? S 20:28 0:00 [xfsaild/sda1]
root 938 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-buf/dm-2]
root 939 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-data/dm-2]
root 940 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-conv/dm-2]
root 941 0.0 0.0 0 0 ? S< 20:28 0:00 [xfs-cil/dm-2]
root 942 0.0 0.0 0 0 ? S 20:28 0:01 [xfsaild/dm-2]
root 954 0.0 0.0 51148 1612 ? S<sl 20:28 0:00 /sbin/auditd -n
root 971 0.0 0.0 80220 824 ? S<sl 20:28 0:00 /sbin/audispd
root 975 0.0 0.0 26196 928 ? S< 20:28 0:00 /usr/sbin/sedispatch
root 978 0.0 0.0 16752 1012 ? SNs 20:28 0:00 /usr/sbin/alsactl -s -n 19 -c -E ALSA_CONFIG_PATH=/etc/alsa/alsactl.
avahi 981 0.0 0.0 30152 1704 ? Ss 20:28 0:00 avahi-daemon: running [nagios1.local]
libstor+ 982 0.0 0.0 4336 356 ? Ss 20:28 0:00 /usr/bin/lsmd -d
root 984 0.0 0.0 195088 4248 ? Ss 20:28 0:11 /usr/bin/vmtoolsd
root 986 0.0 0.0 292032 12168 ? Ssl 20:28 0:02 /usr/sbin/rsyslogd -n
root 988 0.0 0.0 214444 5408 ? Ss 20:28 0:00 /usr/sbin/abrtd -d -s
root 989 0.0 0.0 211984 4504 ? Ss 20:28 0:00 /usr/bin/abrt-watch-log -F BUG: WARNING: at WARNING: CPU: INFO: poss
root 991 0.0 0.0 211984 4508 ? Ss 20:28 0:00 /usr/bin/abrt-watch-log -F Backtrace /var/log/Xorg.0.log -- /usr/bin
root 993 0.0 0.0 326572 4600 ? Ssl 20:28 0:00 /usr/sbin/ModemManager
root 998 0.0 0.0 19292 1272 ? Ss 20:28 0:01 /usr/sbin/irqbalance --foreground
root 999 0.0 0.0 130048 2292 ? Ss 20:28 0:00 /usr/sbin/smartd -n -q never
root 1000 0.0 0.1 550180 18212 ? Ssl 20:28 0:02 /usr/bin/python -Es /usr/sbin/tuned -l -P
chrony 1007 0.0 0.0 26792 1504 ? S 20:28 0:00 /usr/sbin/chronyd -u chrony
rpc 1016 0.0 0.0 39908 868 ? Ss 20:28 0:00 /sbin/rpcbind -w
avahi 1018 0.0 0.0 30028 452 ? S 20:28 0:00 avahi-daemon: chroot helper
root 1019 0.0 0.0 115348 1844 ? Ss 20:28 0:00 /bin/sh /usr/lib/pcsd/pcsd start
root 1020 0.0 0.0 34684 1780 ? Ss 20:28 0:00 /usr/lib/systemd/systemd-logind
root 1021 0.0 0.0 370924 3648 ? Ssl 20:28 0:00 /usr/libexec/accounts-daemon
rtkit 1055 0.0 0.0 164624 1260 ? SNsl 20:28 0:00 /usr/libexec/rtkit-daemon
dbus 1056 0.0 0.0 29512 2480 ? Ss 20:28 0:02 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --
root 1058 0.0 0.0 0 0 ? S< 20:28 0:00 [kworker/2:1H]
root 1064 0.0 0.0 448684 8120 ? Ssl 20:28 0:02 /usr/sbin/NetworkManager --no-daemon
root 1068 0.0 0.0 115216 952 ? S 20:28 0:00 /bin/bash /usr/sbin/ksmtuned
root 1072 0.0 0.0 115212 1484 ? S 20:28 0:00 /bin/bash -c ulimit -S -c 0 >/dev/null 2>&1 ; /usr/bin/ruby -I/usr/l
root 1073 0.0 0.2 363652 35136 ? Sl 20:28 0:06 /usr/bin/ruby -I/usr/lib/pcsd /usr/lib/pcsd/ssl.rb
root 1080 0.0 0.0 203312 1220 ? Ssl 20:28 0:00 /usr/sbin/gssproxy -D
polkitd 1098 0.0 0.1 521800 16264 ? Ssl 20:28 0:10 /usr/lib/polkit-1/polkitd --no-debug
nagios 1240 0.0 0.0 42096 2480 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkUpTime -
nagios 1358 0.0 0.0 42096 2480 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkServic
nagios 1400 0.0 0.0 42096 2480 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkServic
nagios 1401 0.0 0.0 42096 2380 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkCPU -a
nagios 1402 0.0 0.0 42096 2412 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkMem -a M
nagios 1403 0.0 0.0 42096 2216 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkUpTime
nagios 1404 0.0 0.0 46264 2604 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx
nagios 1405 0.0 0.0 42096 2436 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c checkProcSt
nagios 1406 0.0 0.0 42096 2216 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c CheckDriveS
root 1551 0.0 0.0 475080 11428 ? Ssl 20:28 0:00 /usr/sbin/libvirtd
root 1554 0.0 0.0 82488 3604 ? Ss 20:28 0:00 /usr/sbin/sshd -D
redis 1559 0.1 0.0 142688 5732 ? Ssl 20:28 0:14 /usr/bin/redis-server 127.0.0.1:6379
nrpe 1571 0.0 0.0 46312 1456 ? Ss 20:28 0:00 /usr/sbin/nrpe -c /etc/nagios/nrpe.cfg -d
root 1572 0.0 0.0 29272 992 ? Ss 20:28 0:00 /usr/sbin/xinetd -stayalive -pidfile /var/run/xinetd.pid
root 1580 0.0 0.0 126304 1580 ? Ss 20:28 0:00 /usr/sbin/crond -n
root 1586 0.0 0.0 25932 944 ? Ss 20:28 0:00 /usr/sbin/atd -f
root 1589 0.0 0.0 299180 3240 ? Ssl 20:28 0:00 /usr/sbin/gdm
nslcd 1591 0.0 0.0 440156 3332 ? Ssl 20:28 0:00 /usr/sbin/nslcd
root 1666 0.0 0.0 0 0 ? S< 20:28 0:00 [bioset]
root 1670 0.0 0.0 382680 3848 ? Sl 20:28 0:00 /usr/libexec/gdm-simple-slave --display-id /org/gnome/DisplayManager
root 1674 0.0 0.0 0 0 ? S< 20:28 0:00 [drbd-reissue]
nagios 1740 0.0 0.0 42228 2832 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c check_cpu_us
nagios 1827 0.0 0.0 12876 468 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_icmp -H xxx -w 300.0 80 -
root 1834 0.0 0.1 292560 16384 tty1 Ssl+ 20:28 0:01 /usr/bin/Xorg :0 -background none -verbose -auth /run/gdm/auth-for-g
nagios 1842 0.0 0.0 42228 2844 ? S 23:39 0:00 /usr/lib64/nagios/plugins/check_nrpe -H xxx -c check_cpu_us
root 1868 0.0 0.0 123372 1392 pts/0 R+ 23:39 0:00 ps aux
postfix 2129 0.0 0.0 93252 3904 ? S 22:08 0:00 pickup -l -t unix -u
root 2392 0.0 0.0 93148 2136 ? Ss 20:28 0:00 /usr/libexec/postfix/master -w
postfix 2417 0.0 0.0 93320 3928 ? S 20:28 0:00 qmgr -l -t unix -u
root 2710 0.0 0.0 0 0 ? S 23:13 0:00 [kworker/13:1]
root 2836 0.0 0.0 360912 4984 ? Sl 20:28 0:00 gdm-session-worker [pam/gdm-launch-environment]
gdm 2840 0.0 0.0 702980 14196 ? Ssl 20:28 0:00 /usr/bin/gnome-session --autostart /usr/share/gdm/greeter/autostart
gdm 2843 0.0 0.0 13944 604 ? S 20:28 0:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/gnome-session --au
gdm 2880 0.0 0.0 29004 1132 ? Ss 20:28 0:00 /bin/dbus-daemon --fork --print-pid 4 --print-address 6 --session
gdm 2893 0.0 0.0 339968 3264 ? Sl 20:28 0:00 /usr/libexec/at-spi-bus-launcher
gdm 2916 0.0 0.0 28512 1564 ? S 20:28 0:00 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nof
gdm 2919 0.0 0.0 129660 3396 ? Sl 20:28 0:00 /usr/libexec/at-spi2-registryd --use-gnome-session
gdm 2944 0.0 0.1 931940 19716 ? Sl 20:28 0:00 /usr/libexec/gnome-settings-daemon
root 2952 0.0 0.0 257520 7952 ? Ssl 20:28 0:00 /usr/libexec/upowerd
gdm 3036 0.3 0.8 1596204 143280 ? Sl 20:28 0:42 gnome-shell --mode=gdm
colord 3038 0.0 0.0 406576 5820 ? Ssl 20:28 0:00 /usr/libexec/colord
gdm 3045 0.0 0.0 372408 3500 ? S<l 20:28 0:00 /usr/bin/pulseaudio --start --log-target=syslog
gdm 3100 0.0 0.0 180640 2612 ? Sl 20:28 0:00 /usr/libexec/dconf-service
gdm 3114 0.0 0.0 461488 7604 ? Sl 20:28 0:00 /usr/bin/ibus-daemon --replace --xim --panel disable
gdm 3117 0.0 0.0 384160 3552 ? Sl 20:28 0:00 /usr/libexec/ibus-dconf
gdm 3120 0.0 0.0 446224 8504 ? Sl 20:28 0:00 /usr/libexec/ibus-x11 --kill-daemon
gdm 3127 0.0 0.0 310356 5552 ? Sl 20:28 0:00 /usr/libexec/ibus-engine-simple
root 3380 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/2:0]
apache 4795 0.0 0.0 324100 8308 ? S 23:14 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
root 5565 0.0 0.0 143680 5396 ? Ss 23:15 0:00 sshd: root@pts/3
root 5739 0.0 0.0 116672 3324 pts/3 Ss+ 23:15 0:00 -bash
root 6035 0.0 0.0 0 0 ? S< 20:29 0:00 [kworker/3:1H]
root 7258 0.0 0.0 0 0 ? S 23:16 0:00 [kworker/1:0]
root 7710 0.0 0.0 0 0 ? S 21:46 0:00 [kworker/4:1]
root 10544 0.0 0.0 143804 5488 ? Ds 21:22 0:02 sshd: root@pts/0
root 10674 0.0 0.0 0 0 ? S 21:47 0:00 [kworker/10:0]
root 10993 0.0 0.0 116820 3748 pts/0 Ss 21:22 0:01 -bash
root 11514 0.0 0.0 0 0 ? S 22:36 0:00 [kworker/12:1]
root 12046 0.0 0.0 0 0 ? S 21:47 0:01 [kworker/u128:2]
root 15470 0.0 0.0 143800 5452 ? Ss 21:49 0:00 sshd: root@pts/1
root 15571 0.0 0.0 0 0 ? S 23:18 0:00 [kworker/13:2]
root 15808 0.0 0.0 116772 3576 pts/1 Ss+ 21:49 0:00 -bash
root 15866 0.8 0.3 202844 50820 ? Ssl 21:24 1:06 corosync
gdm 15868 0.0 0.0 321208 7516 ? Sl 20:33 0:00 /usr/libexec/mission-control-5
gdm 15876 0.0 0.0 687480 16044 ? Sl 20:33 0:00 /usr/libexec/goa-daemon
gdm 15914 0.0 0.0 321704 6080 ? Sl 20:33 0:01 /usr/libexec/goa-identity-service
root 15925 0.0 0.0 130428 7428 ? Ss 21:24 0:01 /usr/sbin/pacemakerd -f
haclust+ 15926 0.0 0.1 133092 16920 ? Ss 21:24 0:04 /usr/libexec/pacemaker/cib
root 15927 0.0 0.0 134728 9572 ? Ss 21:24 0:01 /usr/libexec/pacemaker/stonithd
root 15928 0.0 0.0 103964 5524 ? Ss 21:24 0:02 /usr/libexec/pacemaker/lrmd
haclust+ 15929 0.0 0.0 124708 8120 ? Ss 21:24 0:01 /usr/libexec/pacemaker/attrd
haclust+ 15930 0.0 0.1 156044 31040 ? Ss 21:24 0:02 /usr/libexec/pacemaker/pengine
haclust+ 15931 0.0 0.1 184304 20804 ? Ss 21:24 0:02 /usr/libexec/pacemaker/crmd
root 16831 0.0 0.0 0 0 ? R 20:34 0:00 [kworker/14:0]
root 23938 0.0 0.0 0 0 ? S 23:24 0:00 [kworker/4:0]
nagios 23943 2.6 0.2 1395196 48020 ? Dsl 23:24 0:24 /usr/bin/nagios -d /etc/nagios/nagios.cfg
nagios 23949 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23952 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23953 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23954 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23955 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23956 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23957 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23958 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23959 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23960 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23961 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23962 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23963 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23964 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23965 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23967 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23968 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23969 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23970 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23971 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23972 0.0 0.0 10896 1052 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23973 0.0 0.0 10896 1056 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23974 0.0 0.0 10896 1060 ? S 23:24 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 23975 0.1 0.0 10896 1056 ? S 23:24 0:01 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 24001 0.0 0.0 60296 10928 ? S 23:24 0:00 /usr/bin/nagios -d /etc/nagios/nagios.cfg
root 26220 0.0 0.0 0 0 ? S 23:24 0:00 [kworker/2:1]
root 29660 0.0 0.0 0 0 ? S< 20:39 0:00 [kworker/1:1H]
root 30062 0.0 0.0 0 0 ? S 22:18 0:00 [kworker/0:4]
root 31340 0.4 0.0 0 0 ? S 23:26 0:03 [drbd_a_r0]
root 31341 0.0 0.0 0 0 ? S< 23:26 0:00 [drbd_as_r0]
root 33763 0.0 0.0 0 0 ? S 23:27 0:00 [kworker/1:2]
root 34144 0.0 0.0 0 0 ? S 22:45 0:00 [kworker/5:1]
root 38035 0.0 0.0 0 0 ? S 20:42 0:00 [kworker/7:2]
root 38469 0.0 0.0 0 0 ? S 22:46 0:00 [kworker/0:2]
root 40504 0.0 0.0 0 0 ? S 23:29 0:00 [kworker/u128:0]
root 41783 0.0 0.0 0 0 ? S 23:30 0:00 [kworker/2:2]
root 47267 0.0 0.0 0 0 ? S 22:58 0:00 [kworker/8:1]
root 48660 0.0 0.0 0 0 ? S 21:37 0:00 [kworker/8:0]
root 49034 0.0 0.0 0 0 ? S 23:32 0:00 [kworker/1:1]
root 49104 0.0 0.0 0 0 ? S 22:25 0:00 [kworker/10:2]
root 49452 0.0 0.0 0 0 ? S 23:00 0:00 [kworker/3:0]
root 50668 0.0 0.0 0 0 ? S 22:26 0:00 [kworker/9:1]
root 52346 0.0 0.0 0 0 ? S 22:26 0:00 [kworker/5:2]
root 53369 0.0 0.0 0 0 ? S 21:39 0:00 [kworker/6:1]
root 53370 0.0 0.0 0 0 ? S 21:39 0:00 [kworker/6:3]
root 54273 0.0 0.0 0 0 ? S 23:02 0:00 [kworker/14:1]
root 55814 0.0 0.0 0 0 ? S 23:03 0:00 [kworker/u129:0]
root 56630 0.0 0.0 0 0 ? S< 23:05 0:00 [drbd0_submit]
root 56640 0.1 0.0 0 0 ? S 23:05 0:02 [drbd_w_r0]
root 56651 0.0 0.0 0 0 ? S 23:05 0:01 [drbd_r_r0]
root 57039 0.0 0.0 145180 6908 ? Ss 23:07 0:01 sshd: root@pts/2
root 57056 0.0 0.0 116772 3572 pts/2 Ss+ 23:07 0:00 -bash
root 57485 0.0 0.0 0 0 ? S 23:08 0:00 [jbd2/drbd0-8]
root 57486 0.0 0.0 0 0 ? S< 23:08 0:00 [ext4-rsv-conver]
root 57487 0.0 0.0 0 0 ? S< 23:08 0:00 [ext4-unrsv-conv]
root 57569 0.0 0.0 321696 10948 ? Ss 23:09 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 57585 0.0 0.0 324100 9124 ? S 23:09 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 57586 0.0 0.0 324132 8156 ? S 23:09 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 57587 0.0 0.0 324100 8240 ? S 23:09 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
apache 57589 0.0 0.0 324100 8328 ? S 23:09 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
root 60008 0.1 0.0 0 0 ? S 23:36 0:00 [kworker/u128:1]
root 61803 0.0 0.0 0 0 ? S 22:06 0:00 [kworker/11:0]
apache 65258 0.0 0.0 324100 8308 ? S 23:13 0:00 /sbin/httpd -DSTATUS -f /etc/httpd/conf/httpd.conf -c PidFile /var/r
root 65504 0.0 0.0 107892 612 ? S 23:39 0:00 sleep 60
[root@nagios1 ~]#
nagmoto
Post
by nagmoto » Sat Apr 11, 2015 10:56 pm
Here is the log showing nagios is still logging into /var/log/message even I set "use_syslog=0" in /etc/nagios/nagios.cfg file.
[root@nagios1 ~]# grep " nagios: " /var/log/messages |grep "Apr 11" |wc -l
3902
[root@nagios1 ~]# grep "^use_syslog" /etc/nagios/nagios.cfg
use_syslog=0
[root@nagios1 ~]# date
Sat Apr 11 23:54:20 EDT 2015
[root@nagios1 ~]#
Post
by tgriep » Mon Apr 13, 2015 10:09 am
I just tested this and it seems to work on my test system.
Can you post your nagios.cfg file?
Can you run the following and post the output here?
tail --lines 100 /var/log/messages
nagmoto
Post
by nagmoto » Mon Apr 13, 2015 3:50 pm
The syslog logging stopped since yesterday(04/12/2015). This is a node on pacemaker under nagios ocf agent's control. I will try to reproduce it on another fresh built test node.
[root@nagios1 ~]# grep -l nagios: /var/log/messages /var/log/messages*
/var/log/messages-20150412
[root@nagios1 ~]#
[root@nagios1 ~]# cat /etc/nagios/nagios.cfg |grep -v ^# |grep -v ^$
log_file=/var/log/nagios/nagios.log
cfg_file=/etc/nagios/objects/commands.cfg
cfg_file=/etc/nagios/objects/contacts.cfg
cfg_file=/etc/nagios/objects/timeperiods.cfg
cfg_file=/etc/nagios/objects/templates.cfg
cfg_file=/etc/nagios/objects/hostgroups.cfg
cfg_file=/etc/nagios/objects/servicegroups.cfg
cfg_file=/etc/nagios/objects/localhost.cfg
cfg_dir=/etc/nagios/servers
object_cache_file=/var/nagios/objects.cache
precached_object_file=/var/nagios/objects.precache
resource_file=/etc/nagios/resource.cfg
status_file=/var/nagios/status.dat
status_update_interval=10
nagios_user=nagios
nagios_group=nagios
check_external_commands=1
command_file=/var/nagios/rw/nagios.cmd
lock_file=/var/nagios/nagios.pid
temp_file=/var/nagios/nagios.tmp
temp_path=/tmp
event_broker_options=-1
broker_module=/usr/local/lib/mk-livestatus/livestatus.o /var/spool/nagios/cmd/livestatus idle_timeout=12000 num_client_threads=20
log_rotation_method=d
log_archive_path=/var/log/nagios/archives
use_syslog=0
log_notifications=1
log_service_retries=1
log_host_retries=1
log_event_handlers=1
log_initial_states=0
log_current_states=1
log_external_commands=1
log_passive_checks=1
max_service_check_spread=30
service_interleave_factor=s
max_host_check_spread=30
max_concurrent_checks=0
max_check_result_reaper_time=30
check_result_path=/var/nagios/spool/checkresults
cached_host_check_horizon=15
cached_service_check_horizon=15
soft_state_dependencies=0
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
service_check_timeout=60
host_check_timeout=30
event_handler_timeout=30
notification_timeout=30
ocsp_timeout=5
perfdata_timeout=5
retain_state_information=1
state_retention_file=/var/nagios/retention.dat
retention_update_interval=60
use_retained_program_state=1
interval_length=60
check_for_updates=1
bare_update_check=0
execute_service_checks=1
execute_host_checks=1
accept_passive_host_checks=1
enable_notifications=0
enable_event_handlers=1
process_performance_data=0
obsess_over_services=0
obsess_over_hosts=0
check_for_orphaned_services=1
check_for_orphaned_hosts=1
check_service_freshness=1
service_check_timeout_state=c
check_host_freshness=0
additional_freshness_latency=15
enable_flap_detection=1
low_host_flap_threshold=5.0
high_host_flap_threshold=20.0
date_format=us
use_regexp_matching=0
use_true_regexp_matching=0
admin_email=nagios@localhost
admin_pager=pagenagios@localhost
daemon_dumps_core=0
enable_environment_macros=0
debug_level=0
debug_verbosity=0
debug_file=/var/log/nagios/nagios.debug
max_debug_file_size=1000000
allow_empty_hostgroup_assignment=0
process_performance_data=1
service_perfdata_file=/var/log/nagios/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=30
service_perfdata_file_processing_command=process-service-perfdata-file
host_perfdata_file=/var/log/nagios/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=30
host_perfdata_file_processing_command=process-host-perfdata-file
[root@nagios1 ~]#
abrist
Red Shirt
Posts: 8334 Joined: Thu Nov 15, 2012 1:20 pm
Post
by abrist » Mon Apr 13, 2015 4:05 pm
Yeah, I just tested this on my 4.1 system and it is working. You must have had multiple parent processes (running with the old config with syslog turned on) or something.
Come to the
Dark Side .
nagmoto
Post
by nagmoto » Tue Apr 14, 2015 9:28 am
please resolve this ticket.
Indeed, I do have multiple nagios.cfg.
[root@nagios1 ~]# locate nagios.cfg
/data/etc/nagios/nagios.cfg
/data2/etc/nagios/nagios.cfg
/etc/nagios.old/nagios.cfg
/etc/nagios.orig/nagios.cfg
[root@nagios1 ~]# grep use_syslog /etc/nagios.orig/nagios.cfg
use_syslog=1
[root@nagios1 ~]#
Post
by tgriep » Tue Apr 14, 2015 9:41 am
I just want to verify that is the logging to /var/log/messages is disabled?
Can we close the post?
