Hi all,
Currently i have nagiosNA setup in our system.
There one source until now still unable to receieve anything maybe due to different subnet?
Is anyone having this issue ?
Unable recieve detail from source
- Box293
- Too Basu
Re: Unable recieve detail from source
Have you opened the ports on the NA server firewall (iptables) to allow the inbound traffic?
If the data is coming from a different subnet then it must traverse routers/firewalls, have you opened the ports to allow this traffic through to the NA server?
lingweican
Is a different subnet. But is a direct connection. in the IPtables source anywhere destination anywhere 9920 is accept
sorry not good in linux
- Box293
- Too Basu
Lets see if the traffic is hitting the NA server.
First install tcpdump:
Then run this command:
9920 is the port you have defined on your source in Network Analyzer AND on the sending device.
yum -y install tcpdumpCode: Select all
tcpdump udp port 9920As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
lingweican
i yum install already. but when i do the command tcpdump udp port 9920 it seem like struck there not moving at all.
- Box293
- Too Basu
lingweican wrote: but when i do the command tcpdump udp port 9920 it seem like struck there not moving at all.
Box293 wrote:If the data is coming from a different subnet then it must traverse routers/firewalls, have you opened the ports to allow this traffic through to the NA server?
If it's in a different subnet, then it must pass through a router. Is that router allowing udp port 9920 from the source to reach the Network Analyzer server?lingweican wrote:Is a different subnet.
