Nagios Email Alerting for internal domain Exchange server
bhartley
Post by bhartley »
Hello ;
I'm part of the IT support department in our company and I'm wondering how I would go about including nagios email notifications as part of our nagios setup on Ubuntu. We have an internal Exchange 2010 machine on our windows domain, and we just need nagios to email alerts to us in IT, basically email flow should stay within our domain and never leave the LAN. There are tutorials out there I see on the web, I could just do with some guidance as they look complex and I don't know if they'd meet our needs.
Ben
jdalrymple
Skynet Drone
Re: Nagios Email Alerting for internal domain Exchange serve
Post by jdalrymple »
Is the intent to E-mail your internal infrastructure still or will you need to send externally? Reallistically it doesn't matter, the 10k foot overview of the process is this:
Separate contacts for this specific service (because)
New contacts use different notification commands for services and potentially hosts if you have them being notified of any host-down situations
Craft your new notification command to use whatever constructs you need to get the message wherever it has to go. Quite often the default notify-service-by-email of `printf "message" | /bin/mail/ -s whatever [email protected]` will suffice.
bhartley
Post by bhartley »
Thanks for coming back to me so quick, yes please this scenario requires us to keep nagios sending mail to Exchange which we can receive from Exchange, so just internal for this.
Where in the file structure is the config file with the contact information to add/modify located, I'm not sure quite where to start with setting this up.
Many Thanks
jdalrymple
Skynet Drone
bhartley wrote:Where in the file structure is the config file with the contact information to add/modify located
Most typically people will use contacts.cfg and/or contactgroups.cfg to define their contacts. Our documentation is all on sourceforge which is crippled right now so I'll have to point you to Google's cached versions of the docs site:
http://webcache.googleusercontent.com/s ... clnk&gl=us
Scroll down to contacts to see how to define one (scroll - don't bother trying to use the anchor links). You should already have some that use your unbroken Exchange - you just need to define some special contacts with special commands that will still function even when your Exchange is broken.
I guess that leaves me with a question though - how do you intend to use your internal Exchange to notify about your internal Exchange being broken? I thought the whole point was to send E-mails to users indicating that their normal E-mail is broken.
bhartley
Post by bhartley »
What we'll be using this for is for the hosts that I've defined in Nagios to alert us to downtime on them such as our Air con units, servers, routers, CCTV etc (excluding the exchange server on this occasion). - I am trying to add more to the contacts.cfg file but after performing "service nagios restart" command in the terminal session I'm faced with the config error, as soon as I add the last two lines from the example you've quoted me I receive the error after the restart:
service_notification_commands notify-by-email
host_notification_commands host-notify-by-email
Please see the attachment with screen prints on my "contacts.cfg" config for nagios.
Thanks for pointing us in the right direction.
Ben
Screen prints.docx
(513.36 KiB) Downloaded 119 times
jdalrymple
Skynet Drone
I'm a little lost... but let me start by turning back around to the beginning and making sure I even understood the problem properly.
It was my understanding that you had a Nagios Core up and running, monitoring and alerting when problems occurred. It was my understanding that you wanted to have a way to alert your users when your internal mail system failed. I'm feeling like I misunderstood though. Can you restate the situation for me?
As for the actual error when trying to restart Nagios - in order to troubleshoot we'd need to see the error output, or the output from config validation:
Is how you'd get that in a default install. You may have to adjust the paths a bit to fit your environment.
Your notification commands are defined wrong, they should be like this. Try changing them to below.
service_notification_commands notify-service-by-email
host_notification_commands notify-host-by-email
