check_cisco_firewall.sh email alert on Warning status
mkhan12282
Post by mkhan12282 »
Nagios core: 3.5.0
Hello
Can we configure Nagios to send out email alert when failover status = warning? As of now it shows this status in the portal but we would like to get alerted when failover happens.
I have gone through these link already.
https://exchange.nagios.org/directory/P ... IX/details
Thank you.
MK
Re: check_cisco_firewall.sh email alert on Warning status
Yes, you can setup your service check to notify you on a warning.
For example, you would have to edit your service check and enable notifications, set a period, a notification interval and a contact.
Adjust to your needs.
notification_interval           60
notifications_enabled           1
contacts                        nagiosadmin
Then your contact will have to be setup also like below.
define contact {
        contact_name                            nagiosadmin
        alias                                   Nagios Administrator
        host_notifications_enabled              1
        service_notifications_enabled           1
        host_notification_period                24x7
        service_notification_period             24x7
        host_notification_options               d,u,r,f,s
        service_notification_options            w,u,c,r,f,s
        host_notification_commands               	notify-host-by-email
        service_notification_commands            	notify-service-by-email
        email                                   nagios@localhost
The above are example but here is a link to the online documentation that you can review further.
https://assets.nagios.com/downloads/nag ... n/toc.html
If you have any problems, please post the configs so we can review them.
mkhan12282
Hi
Thanks for the input.
Sorry, i missed to add that we have notfications enabled, we just need to asa failover warning status to trigger email alert too. So based on what you suggested me, i have added another contact as "asa.failover" and added "w" in the service_notification_options. Please find doc attached. Appologies i had to hide some info relating to domains.
You will also note that i have added multiple emails in the "email" of "contacts.cfg". will this work? As far as nagios didn't complaint during the preflight check.
please let me know if you find the config OK
Thank you.
MK
nagios.docx
(45.33 KiB) Downloaded 211 times
You will have to create a separate contact, one per email address and then add them to the contact group and use that for your notifications.
