Unable to generate PDF or JPG reports
mcleodc
Post by mcleodc »
I am running Nagios XI v5 and am starting trying to generate SLA reports. I can generate reports but get an error when trying to download or email a PDF. If emailed i end up with a 1Kb PDF if downloaded i get the attached error.
Chris
hsmith
Agent Smith
Re: Unable to generate PDF or JPG reports
Post by hsmith »
A few things to check here since I was unable to reproduce this:
  • -Are you using SSL?
    -Can you access the URL that the error is giving you?
    --If you can't, can you using the IP address?
    -Is this XI5R1.0 or XI5 2.0.0 ?
Former Nagios Employee.
me.
mcleodc
Post by mcleodc »
Thanks for the reply.
I am not using SSL and i am running 5.1. I can access the URL it takes me to the report and displays correctly. Just no pdf download.
Chris
What is the output of the following commands?
hostname
cat /etc/hosts
mcleodc
Post by mcleodc »
Here you go
[root@kinnag /]# hostname
kinnag
[root@kinnag /]# cat /etc/hosts
# Do not remove the following line, or various programs
# that require network functionality will fail.
127.0.0.1 kinnag localhost
::1 localhost6.localdomain6 localhost6
192.168.136.25 edrington.co.uk
[root@kinnag /]#
chris
mcleodc
Post by mcleodc »
I've upgraded to 5.2 and still see the same issue.
chris
hsmith
Agent Smith
Post by hsmith »
Is there anything interesting happening in your logs when you try to do this?
Run this command:
tail -f /var/log/httpd/access_log
and then try to generate the report.
me.
mcleodc
Post by mcleodc »
HI,
Nothing at all. I have attached the logs.
Chris
hsmith
Agent Smith
Post by hsmith »
Have you tried multiple browsers? It looks like you're using Safari. I want to make sure that's not where the issue is coming from.
me.
mcleodc
Post by mcleodc »
I was using chrome on my Windows 7 laptop odd it shows as safari! I have also tried using Firefox.
chris
