We are installing linux-nrpe-agent on the linux agent servers . As a good practise we are planning to create a filesystem for agent like /products/nagios .
We would want to know what would be the idle space which need to be allocated for the agent ? Will 1 GB work?
Please provide your inputs on the best practise for agent installation directory.
linux-nrpe-agent installation
Regards,
Ranjit W
Ranjit W
Re: linux-nrpe-agent installation
The NRPE binary on my system is 142K in size. On a full XI install with default plugins, my plugins directory is only 9.1M in size. On a NRPE install you are likely to not have the same plugins that XI installs by default so that number may be lower. Given this information, I would say 1G for just the NRPE and related binaries should be just fine, but that is not including log files which obviously I can't estimate how big those will be.
I am looking for space which need to allocated on the client machine .
Regards,
Ranjit W
Ranjit W
As I mentioned in my last post, 1GB should be fine for the NRPE binary and plugins. I have no way of knowing how big or how fast any of your log files will grow, so I can't speak to that, but for just the binaries 1GB looks like it will be plenty.
