Issues integrating NNA into XI
lucas.shelton
Post by lucas.shelton »
I've followed the steps in the Nagios Network Analyzer guide to integrate NNA into XI but am still having issues. When I click on the hostname it says it is UP but there is an unknown error running the plugin. It says the host state is down. See attached screen shots.
Re: Issues integrating NNA into XI
What XI and NNA versions are you running?
What NNA component do you have in XI under Admin -> Manage Components?
lucas.shelton
tmcdonald wrote:What XI and NNA versions are you running?
XI 2014R2.3, NNA 2R1.0. NNA component is version 1.2.2.
Post by Box293 »
Can you go into Core Configuration Manager
Monitoring > Hosts
Edit the host "NNA Sourcegroup - All Sources"
Click the "Test Check Command Button"
What is the output?
Also when viewing the output, the full command executed is shown. Copy this line and paste it into an ssh session and add --verbose to the end, something like:
/usr/local/nagios/libexec/check_nna.py -H 10.25.5.70 -K c2e1a2e6ae8bc2469ed97b08339aaab6619b4590 -G 1 --exists --verbose
What is output?
lucas.shelton
Box293 wrote:Can you go into Core Configuration Manager
Monitoring > Hosts
What is the output?
What is output?
Here's the output of the Test Check Command button:
COMMAND: /usr/local/nagios/libexec/check_nna.py -H nfcollector1.drake.edu -K 260bb2d78a0fe7e919cd48c1aa4106fbbd24e94a -G 1 --exists
OUTPUT: UP - group exists
UNKNOWN - Error occurred while running the plugin.
Here's the output from the SSH session:
bash: /usr/local/nagios/libexec/check_nna.py: No such file or directory
What is the version of the "Nagios Network Analyzer" wizard that you are using? Run the following command on the Nagios XI box and show us the output:
ll /usr/local/nagios/libexec/check_nna.py
Have you tried updating the "Nagios Network Analyzer" wizard "Nagios Network Analyzer Integration" component to see if this is going to fix the issue?
Admin->Manage Components->Check for Updates
Admin->Manage Config Wizards->Check for Updates
lucas.shelton
My apologies on the post above, I ran that command on the NNA VM and not the XI VM. Here is the output from the command via SSH in XI:
[lshelton@netmon ~]$ /usr/local/nagios/libexec/check_nna.py -H nfcollector1.drake.edu -K 260bb2d78a0fe7e919cd48c1aa4106fbbd24e94a -G 1 --exists --verbose
UP - group exists
And error was encountered:
0
lucas.shelton
lmiltchev wrote:What is the version of the "Nagios Network Analyzer" wizard that you are using? Run the following command on the Nagios XI box and show us the output:
[lshelton@netmon ~]$ ll /usr/local/nagios/libexec/check_nna.py
-rwxr-xr-x 1 root root 10037 Dec 30  2014 /usr/local/nagios/libexec/check_nna.py
There are no updates for the wizards.
jolson
Attack Rabbit
Post by jolson »
How many Sources are in your 'All Sources' group? Mine contained 2 Sources (I'm using the same versions of NNA and XI as you) and my query completed with no problems.
[root@localhost ~]# /usr/local/nagios/libexec/check_nna.py -H 192.168.4.146 -K fe51760996xxxxxxx8eb3 -G 1 --exists --verbose
UP - group exists
What is your python version?
python --version
Twits Blog
lucas.shelton
I currently have four sources but was having the same issue when I only had two.
Python 2.4.3
