How to connect to my remote windows computers
nader
Post by nader »
I'm new in Nagios XI and a little lost !
I have some computer out of my office that connect to internet ,should i use Nagios XI to check if those computer running?
hsmith
Agent Smith
Re: How to connect to my remote windows computers
Post by hsmith »
nader wrote:I'm new in Nagios XI and a little lost !
Gotta start somewhere!
nader wrote:I have some computer out of my office that connect to internet ,should i use Nagios XI to check if those computer running?
What exactly are you looking to monitor? If you're able to communicate with those hosts, this should be pretty trivial.
Former Nagios Employee.
me.
nader
Post by nader »
Want to check cpu temperatue and hard drive left capacity and cameras that connect to these remote computers that each of them has separate DNS and valid IP.
hsmith
Agent Smith
Post by hsmith »
nader wrote:Want to check cpu temperatue
Depends on if that information is available. What kind of OS?
nader wrote:hard drive left capacity
A lot of different ways to do it. Again, what OS?
nader wrote:and cameras that connect to these remote computers
Connect how? What do you want to monitor on them? What model?
nader wrote:that each of them has separate DNS and valid IP.
What OS? Makes a world of difference. I am slightly confused since above you said that they are connected to the computer.
me.
nader
Post by nader »
Thanks for your reply, All OS are windows 7 or 8 ,
I want to use NAGIOS to find out the windows stability and cameras that now I can see via DNS and port.
Post by Box293 »
Start off by monitoring free space by using NSClient++
Then use the Windows Server Wizard.
nader wrote:cameras that now I can see via DNS and port.
Are these cameras only accessible from that Windows PC, or can any device on the network get to them?
