Thank you for the answer.
I have some questions more (sorry for this but these are my first approaches to SNMP).
1.
Some OIDs show a right data, for example the temperature thresholds, but other OIDs show a wrong data, for example the temperature OID shows 18° while the IMM shows 20°.
Is it normal I see this difference?
2.
Some OIDs are very long, for example the OID for the temperature is: .1.3.6.1.4.1.2.6.159.1.1.80.1.1.2.27.97.109.98.105.101.110.116.32.116.101.109.112.58.50.102.50.98.48.49.102.52.53.48.49.102.53.99
Is this normal?
3.
Other OIDs doesn’t give me any answers, as "ibmSystemRaidUp" "1.3.6.1.4.1.2.6.159.1.1.200.0"
while other OIDs give me
Timeout: No Response, as "ibmSystemRaid" "1.3.6.1.4.1.2.6.159.1.1.200"
Is also this a normal behaviour of the system?
4.
About the MIB file, I get it from the installation path of the IBM System Director.
Is it supposed to be the right MIB file?
When I asked about the X3650M2 MIB on the IBM forum, I get
this answer, but to be honest I don't know how use the files they linked.
5.
In the end, how did you translate the MIB file? Is there any tool for this?
Sorry for so many questions and thank your for your patience.
