Our Security team needs to whitelist all the sites that Nagios needs to perform updates, etc.
Can you provide me with such a list ? These should be all the sites NagiosXI uses when I select Update via the GUI and also all the components & wizards now that I can do it via the GUI.
Thanks... Fred
Whitelisting Nagios sites
Fred Kroeger
Re: Whitelisting Nagios sites
Hi Fred,
You're going to want to whitelist api.nagios.com and assets.nagios.com. Maybe just nagios.com for good measure (if you can get away with that). While you don't *need* it, I would also recommend you have access to https://exchange.nagios.org, as that is where you find plugins and such.
Former Nagios Employee.
me.
me.
