Upgrade from nagiso XI 2014R2.6 to Nagios XI 5
emartine
Post by emartine »
I went through the process of updating the test environment via the Admin --> Check for Updates Now --> Upgrade to Latest Version
Seems to have gotten stuck here however
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Warning: RPMDB altered outside of yum.
Installing : pakchois-0.4-3.2.el6.x86_64 1/5
Installing : neon-0.29.3-3.el6_4.x86_64 2/5
Installing : subversion-1.6.11-15.el6_7.x86_64 3/5
Installing : perl-Math-Calc-Units-1.07-1.el6.rf.noarch 4/5
Installing : perl-Number-Format-1.73-3.el6.noarch 5/5
Uploading Package Profile
<Froze at this point attempting to upload package profile.>
Should I kill this if so how?
hsmith
Agent Smith
Re: Upgrade from nagiso XI 2014R2.6 to Nagios XI 5
Post by hsmith »
I would just load another page. What version of CentOS is this on?
Former Nagios Employee.
me.
emartine
Post by emartine »
tail -f /var/log/messages
Dec 1 15:32:18 nagiosxi abrt: detected unhandled Python exception in '/usr/
Dec 1 15:32:18 nagiosxi abrtd: Directory 'pyhook-2015-12-01-15:32:18-21534'
Dec 1 15:32:18 nagiosxi abrt-server[21541]: Saved Python crash dump of pid
Dec 1 15:32:18 nagiosxi abrtd: Executable '/usr/local/nagios/libexec/check_
Dec 1 15:32:18 nagiosxi abrtd: 'post-create' on '/var/spool/abrt/pyhook-201
Dec 1 15:32:18 nagiosxi abrtd: Deleting problem directory '/var/spool/abrt/
Dec 1 15:32:19 nagiosxi abrt: detected unhandled Python exception in '/usr/
Dec 1 15:32:19 nagiosxi abrt-server[21588]: Not saving repeating crash in '
This may not be relevant.
emartine
Post by emartine »
Red Hat Enterprise Linux Server release 6.7 (Santiago) is the version of Linux running on this server
Even if I load another page and come back to the updates page I keep seeing the same thing.
<<< Update in progress. Please wait. Update may take a few minutes.>>>
emartine
Post by emartine »
Seems to have failed on its own.
Parse errors: Bad plan. You planned 93 tests but ran 2.
Files=16, Tests=190, 1 wallclock secs ( 0.06 usr 0.02 sys + 0.63 cusr 0.12 csys = 0.83 CPU)
Result: FAIL
Failed 14/16 test programs. 39/190 subtests failed.
make: *** [test_dynamic] Error 255
Can you run the following on the XI server and post back the output?
yum list installed perl-Class-Accessor
emartine
Post by emartine »
On the test server that I am upgrading I get
Error: No matching Packages to list
Does it need to be installed?
My current production server also does not have this installed.
emartine
Post by emartine »
yum list *Accessor
Loaded plugins: package_upload, product-id, security, subscription-manager
Installed Packages
perl-Object-Accessor.x86_64 1:0.34-141.el6_7.1 @rhel-6-server-rpms
Available Packages
perl-Class-Data-Accessor.noarch 0.04004-1.el6.rf rpmforge
The perl-Class-Accessor package... where does it come from?
epel repo.
yum provides perl-Class-Accessor
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
 * base: mirror.tzulo.com
 * epel: mirror.steadfast.net
 * extras: mirrors.gigenet.com
 * rpmforge: mirror.team-cymru.org
 * updates: centos.chi.host-engine.com
perl-Class-Accessor-0.34-12.el7.noarch : Automated accessor generation
Repo        : epel
Can you run the following command and show the output?
yum repolist -v
Also, post the entire "upgrade.log".
emartine
Post by emartine »
I enabled the epel repos and we got further with the installation but it failed again.
yum repolist -v
Loading "package_upload" plugin
Loading "product-id" plugin
Loading "security" plugin
Loading "subscription-manager" plugin
Updating Subscription Management repositories.
Config time: 0.424
Yum Version: 3.2.29
Setting up Package Sacks
pkgsack time: 0.088
Repo-id      : epel
Repo-name    : Extra Packages for Enterprise Linux 6 - x86_64
Repo-revision: 1449089382
Repo-tags    : binary-x86_64
Repo-updated : Wed Dec  2 14:51:22 2015
Repo-pkgs    : 11,886
Repo-size    : 11 G
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=epel-6&arch=x86_64
  Updated    : Wed Dec  2 14:51:22 2015
Repo-baseurl : <url>//mirror.unl.edu/epel/6/x86_64/ (36 more)
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 08:48:14 2015)
Repo-id      : epel-debuginfo
Repo-name    : Extra Packages for Enterprise Linux 6 - x86_64 - Debug
Repo-revision: 1449088133
Repo-tags    : debuginfo-x86_64
Repo-updated : Wed Dec  2 14:29:39 2015
Repo-pkgs    : 2,210
Repo-size    : 7.5 G
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=epel-debug-6&arch=x86_64
  Updated    : Wed Dec  2 14:29:39 2015
Repo-baseurl : <url>//mirror.cs.pitt.edu/epel/6/x86_64/debug/ (31 more)
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 08:48:15 2015)
Repo-id      : epel-source
Repo-name    : Extra Packages for Enterprise Linux 6 - x86_64 - Source
Repo-revision: 1449088573
Repo-tags    : source
Repo-updated : Wed Dec  2 14:51:27 2015
Repo-pkgs    : 0
Repo-size    : 0
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=epel-source-6&arch=x86_64
  Updated    : Wed Dec  2 14:51:27 2015
Repo-baseurl : <url>//mirror.cs.pitt.edu/epel/6/SRPMS/ (33 more)
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 08:48:17 2015)
Repo-id      : epel-testing
Repo-name    : Extra Packages for Enterprise Linux 6 - Testing - x86_64
Repo-revision: 1449000033
Repo-updated : Tue Dec  1 14:01:00 2015
Repo-pkgs    : 1,138
Repo-size    : 1.8 G
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=testing-epel6&arch=x86_64
  Updated    : Tue Dec  1 14:01:00 2015
Repo-baseurl : <url>//kdeforge2.unl.edu/mirrors/epel/testing/6/x86_64/ (33 more)
Repo-id      : epel-testing-debuginfo
Repo-name    : Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Debug
Repo-revision: 1448999897
Repo-updated : Tue Dec  1 13:58:22 2015
Repo-pkgs    : 87
Repo-size    : 455 M
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=testing-debug-epel6&arch=x86_64
  Updated    : Tue Dec  1 13:58:22 2015
Repo-baseurl : <url>//linux.mirrors.es.net/fedora-epel/testing/6/x86_64/debug/ (31 more)
Repo-id      : epel-testing-source
Repo-name    : Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Source
Repo-revision: 1448999929
Repo-tags    : source
Repo-updated : Tue Dec  1 14:01:03 2015
Repo-pkgs    : 0
Repo-size    : 0
Repo-metalink: <url>mirrors.fedoraproject.org/metalink?repo=testing-source-epel6&arch=x86_64
  Updated    : Tue Dec  1 14:01:03 2015
Repo-baseurl : <url>//archive.linux.duke.edu/pub/epel/testing/6/SRPMS/ (31 more)
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 08:48:18 2015)
Repo-id      : misc
Repo-name    : Miscellaneous Packages (not signed)
Repo-updated : Fri Aug 28 17:13:39 2015
Repo-pkgs    : 35
Repo-size    : 243 M
Repo-baseurl : <url>//<server>/cbis/el6/misc/x86_64
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 08:34:28 2015)
Repo-excluded: 2
Repo-id      : nagios-base
Repo-name    : Nagios
Repo-revision: 1444772471
Repo-updated : Tue Oct 13 16:42:59 2015
Repo-pkgs    : 151
Repo-size    : 1.1 G
Repo-baseurl : <url>//repo.nagios.com/nagios/6/
Repo-id      : nagiosxi-deps
Repo-name    : Nagios XI Dependencies
Repo-revision: 1444743584
Repo-updated : Tue Oct 13 08:39:45 2015
Repo-pkgs    : 33
Repo-size    : 13 M
Repo-baseurl : <url>//repo.nagios.com/nagiosxi-deps/6/
Repo-id      : rhel-6-server-extras-rpms
Repo-name    : Red Hat Enterprise Linux 6 Server - Extras (RPMs)
Repo-revision: 1448135583
Repo-updated : Sat Nov 21 13:53:03 2015
Repo-pkgs    : 75
Repo-size    : 106 M
Repo-baseurl : <url><server>/pulp/repos/UCM/Library/Composite/content/dist/rhel/server/6/6Server/x86_64/extras/os
Repo-expire  : 86,400 second(s) (last: Thu Dec  3 08:34:29 2015)
Repo-id      : rhel-6-server-optional-rpms
Repo-name    : Red Hat Enterprise Linux 6 Server - Optional (RPMs)
Repo-revision: 1448138511
Repo-updated : Sat Nov 21 14:41:51 2015
Repo-pkgs    : 0
Repo-size    : 0
Repo-baseurl : <url><server>/pulp/repos/UCM/Library/Composite/content/dist/rhel/server/6/6Server/x86_64/optional/os
Repo-id      : rhel-6-server-rh-common-rpms
Repo-name    : Red Hat Enterprise Linux 6 Server - RH Common (RPMs)
Repo-revision: 1448135585
Repo-updated : Sat Nov 21 13:53:05 2015
Repo-pkgs    : 204
Repo-size    : 8.1 G
Repo-baseurl : <url><server>/pulp/repos/UCM/Library/Composite/content/dist/rhel/server/6/6Server/x86_64/rh-common/os
Repo-id      : rhel-6-server-rpms
Repo-name    : Red Hat Enterprise Linux 6 Server (RPMs)
Repo-revision: 1448139945
Repo-updated : Sat Nov 21 15:05:45 2015
Repo-pkgs    : 16,340
Repo-size    : 28 G
Repo-baseurl : <url><server>/pulp/repos/UCM/Library/Composite/content/dist/rhel/server/6/6Server/x86_64/os
Repo-id      : rpmforge
Repo-name    : RHEL 6Server - RPMforge.net - dag
Repo-updated : Thu Jul 10 20:46:59 2014
Repo-pkgs    : 4,718
Repo-size    : 2.2 G
Repo-baseurl : <url>//apt.sw.be/redhat/el6/en/x86_64/rpmforge
Repo-mirrors : <url>//mirrorlist.repoforge.org/el6/mirrors-rpmforge
Repo-expire  : 21,600 second(s) (last: Thu Dec  3 09:15:30 2015)
Repo-id      : rpmforge-extras
Repo-name    : RHEL 6Server - RPMforge.net - extras
Repo-updated : Thu Jul 10 20:47:04 2014
Repo-pkgs    : 711
Repo-size    : 398 M
Repo-baseurl : <url>//apt.sw.be/redhat/el6/en/x86_64/extras
Repo-mirrors : <url>//mirrorlist.repoforge.org/el6/mirrors-rpmforge-extras
repolist: 37,588
Installed Packages
perl-Class-Accessor.noarch                                                      0.31-0.6.1.el6                                                       @epel
at this point the installation seems to have gotten further but the website now reports error 500
#   Failed test 'exits(3) with  -r 99 '
#   at t/check_stuff.t line 37.
#          got: '2'
#     expected: '3'
#   Failed test 'UNKNOWN (warning: invalid -r) with  -r 99 '
#   at t/check_stuff.t line 38.
#     doesn't match '(?i-xsm:UNKNOWN.+invalid)'
Base class package "Config::Tiny" is empty.
    (Perhaps you need to 'use' the module which defines that package first,
    or make that module available in @INC (@INC contains: lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosx                                           i/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share                                           /perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
 at lib/Nagios/Monitoring/Plugin/Config.pm line 6
BEGIN failed--compilation aborted at lib/Nagios/Monitoring/Plugin/Config.pm line 6.
Compilation failed in require at lib/Nagios/Monitoring/Plugin/Getopt.pm line 16.
BEGIN failed--compilation aborted at lib/Nagios/Monitoring/Plugin/Getopt.pm line 16.
Compilation failed in require at lib/Nagios/Monitoring/Plugin.pm line 64.
#   Failed test 'exits(1) with  -w 10:15 -c~:15 -r 0'
#   at t/check_stuff.t line 57.
#          got: '2'
#     expected: '1'
#   Failed test 'looks WARNING with  -w 10:15 -c~:15 -r 0'
#   at t/check_stuff.t line 58.
#     doesn't match '(?i-xsm:^STUFF WARNING)'
#   Failed test 'looks CRITICAL with  -w 10:15 -c~:15 -r 15.8'
#     doesn't match '(?i-xsm:^STUFF CRITICAL)'
#   Failed test 'exits(0) with  -w 10:15 -c~:15 -r 11'
#          got: '2'
#     expected: '0'
#   Failed test 'looks OK with  -w 10:15 -c~:15 -r 11'
#     doesn't match '(?i-xsm:^STUFF OK)'
# Looks like you failed 13 tests of 14.
t/check_stuff.t ..............................
Dubious, test returned 13 (wstat 3328, 0xd00)
Failed 13/14 subtests
t/Nagios-Monitoring-Plugin-01.t .............. ok
t/Nagios-Monitoring-Plugin-02.t .............. ok
t/Nagios-Monitoring-Plugin-03.t .............. ok
    or make that module available in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/su                                           bcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/per                                           l5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
 at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Config.pm line 6
BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Config.pm li                                           ne 6.
Compilation failed in require at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Getopt.pm line 1                                           6.
BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Getopt.pm li                                           ne 16.
Compilation failed in require at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin.pm line 64.
# Looks like you planned 30 tests but ran 4.
# Looks like your test exited with 2 just after 4.
t/Nagios-Monitoring-Plugin-04.t ..............
Dubious, test returned 2 (wstat 512, 0x200)
Failed 26/30 subtests
#   Failed test 'use Nagios::Monitoring::Plugin::Getopt;'
#   at t/Nagios-Monitoring-Plugin-Functions-01.t line 11.
#     Tried to use 'Nagios::Monitoring::Plugin::Getopt'.
#     Error:  Base class package "Config::Tiny" is empty.
#     (Perhaps you need to 'use' the module which defines that package first,
#     or make that module available in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/                                           subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/p                                           erl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
#  at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Config.pm line 6
# BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Config.pm                                            line 6.
# Compilation failed in require at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Getopt.pm line                                            16.
# BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Getopt.pm                                            line 16.
# Compilation failed in require at (eval 17) line 2.
# BEGIN failed--compilation aborted at (eval 17) line 2.
#   Failed test 'Version number for Nagios::Monitoring::Plugin::Getopt the same as Functions: 0.51'
#   at t/Nagios-Monitoring-Plugin-Functions-01.t line 15.
#          got: undef
#     expected: '0.51'
# Looks like you failed 2 tests of 113.
t/Nagios-Monitoring-Plugin-Functions-01.t ....
Failed 2/113 subtests
t/Nagios-Monitoring-Plugin-Functions-02.t .... ok
t/Nagios-Monitoring-Plugin-Functions-03.t .... ok
#   at t/Nagios-Monitoring-Plugin-Getopt-01.t line 6.
# Compilation failed in require at (eval 4) line 2.
# BEGIN failed--compilation aborted at (eval 4) line 2.
Can't use string ("plugin") as a HASH ref while "strict refs" in use at /usr/share/perl5/vendor_perl/Class/Accessor.pm line 122.
# Looks like you planned 76 tests but ran 1.
# Looks like you failed 1 test of 1 run.
# Looks like your test exited with 255 just after 1.
t/Nagios-Monitoring-Plugin-Getopt-01.t .......
Dubious, test returned 255 (wstat 65280, 0xff00)
Failed 76/76 subtests
#   at t/Nagios-Monitoring-Plugin-Getopt-02.t line 6.
# Looks like you planned 14 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-02.t .......
Failed 14/14 subtests
#   at t/Nagios-Monitoring-Plugin-Getopt-03.t line 9.
# Compilation failed in require at (eval 8) line 2.
# BEGIN failed--compilation aborted at (eval 8) line 2.
Can't use string ("usage") as a HASH ref while "strict refs" in use at /usr/share/perl5/vendor_perl/Class/Accessor.pm line 122.
# Looks like you failed 1 test of 1.
t/Nagios-Monitoring-Plugin-Getopt-03.t .......
Failed 1/1 subtests
#   at t/Nagios-Monitoring-Plugin-Getopt-04.t line 6.
# Looks like you planned 11 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-04.t .......
Failed 11/11 subtests
t/Nagios-Monitoring-Plugin-Performance-02.t .. ok
t/Nagios-Monitoring-Plugin-Performance.t ..... ok
t/Nagios-Monitoring-Plugin-Range.t ........... ok
t/Nagios-Monitoring-Plugin-Threshold.t ....... ok
Test Summary Report
t/check_stuff.t                            (Wstat: 3328 Tests: 14 Failed: 13)
  Failed tests:  1-10, 12-14
  Non-zero exit status: 13
t/Nagios-Monitoring-Plugin-04.t            (Wstat: 512 Tests: 4 Failed: 0)
  Non-zero exit status: 2
  Parse errors: Bad plan.  You planned 30 tests but ran 4.
t/Nagios-Monitoring-Plugin-Functions-01.t  (Wstat: 512 Tests: 113 Failed: 2)
  Failed tests:  6-7
t/Nagios-Monitoring-Plugin-Getopt-01.t     (Wstat: 65280 Tests: 1 Failed: 1)
  Failed test:  1
  Non-zero exit status: 255
  Parse errors: Bad plan.  You planned 76 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-02.t     (Wstat: 65280 Tests: 1 Failed: 1)
  Failed test:  1
  Parse errors: Bad plan.  You planned 14 tests but ran 1.
t/Nagios-Monitoring-Plugin-Getopt-03.t     (Wstat: 65280 Tests: 1 Failed: 1)
  Failed test:  1
t/Nagios-Monitoring-Plugin-Getopt-04.t     (Wstat: 65280 Tests: 1 Failed: 1)
  Failed test:  1
  Parse errors: Bad plan.  You planned 11 tests but ran 1.
Files=16, Tests=837,  1 wallclock secs ( 0.11 usr  0.03 sys +  0.86 cusr  0.13 csys =  1.13 CPU)
Result: FAIL
Failed 7/16 test programs. 19/837 subtests failed.
