Windows monitor Prerequisites
tomi3
Post by tomi3 »
Hi buddy,
I'm using student version Core VM 4.1.1, while looking at the monitoring windows machines guide (https://assets.nagios.com/downloads/nag ... ndows.html), there is a Prerequisites saying:
Edit the main Nagios config file.
vi /usr/local/nagios/etc/nagios.cfg
Remove the leading pound (#) sign from the following line in the main configuration file:
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
However, when I vi /usr/local/nagios/etc/nagios.cfg, I didn't find there is a entry named #cfg_file=/usr/local/nagios/etc/objects/windows.cfg, am I missing something?
tomi3
Re: Windows monitor Prerequisites
Post by tomi3 »
I can only find below objects:
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
You can add your own line like so below the commented ones out -
This tells nagios to look for the file /usr/local/nagios/etc/objects/windows.cfg and read any definitions (whether it be for hosts / services / etc.)
Here are the contents of windows.cfg, remember this is just a sample configuration so you will need to make changes to it.
# WINDOWS.CFG - SAMPLE CONFIG FILE FOR MONITORING A WINDOWS MACHINE
# NOTES: This config file assumes that you are using the sample configuration
#        files that get installed with the Nagios quickstart guide.
# HOST DEFINITIONS
# Define a host for the Windows machine we'll be monitoring
# Change the host_name, alias, and address to fit your situation
        use             windows-server  ; Inherit default values from a template
        host_name       winserver       ; The name we're giving to this host
        alias           My Windows Server       ; A longer name associated with the host
        address         192.168.1.2     ; IP address of the host
# HOST GROUP DEFINITIONS
# Define a hostgroup for Windows machines
# All hosts that use the windows-server template will automatically be a member of this group
define hostgroup{
        hostgroup_name  windows-servers ; The name of the hostgroup
        alias           Windows Servers ; Long name of the group
# SERVICE DEFINITIONS
# Create a service for monitoring the version of NSCLient++ that is installed
# Change the host_name to match the name of the host you defined above
        host_name               winserver
        service_description     NSClient++ Version
        check_command           check_nt!CLIENTVERSION
# Create a service for monitoring the uptime of the server
        host_name               winserver
        service_description     Uptime
        check_command           check_nt!UPTIME
# Create a service for monitoring CPU load
        host_name               winserver
        service_description     CPU Load
        check_command           check_nt!CPULOAD!-l 5,80,90
# Create a service for monitoring memory usage
        host_name               winserver
        service_description     Memory Usage
        check_command           check_nt!MEMUSE!-w 80 -c 90
# Create a service for monitoring C:\ disk usage
        host_name               winserver
        service_description     C:\ Drive Space
        check_command           check_nt!USEDDISKSPACE!-l c -w 80 -c 90
# Create a service for monitoring the W3SVC service
        host_name               winserver
        service_description     W3SVC
        check_command           check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
# Create a service for monitoring the Explorer.exe process
        host_name               winserver
        service_description     Explorer
        check_command           check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
