while configuring router i am getting error ,
Switch is currently down
the switch does not exist at the address you specified
SNMP support on the switch is disable
i have tried to run the commend which it gives after it at root but the issue remain same
Hopes for your suggestions
Network Switch And Router Monitoring Wizard Error ?
mohsin2011
