Hi All,
I am trying to install Nagios XI 5.2.5 on RHEL 7.2. Installation is failing with below error message. install.log file is attached. Please help in solving the issue.
Running './E-importnagiosql'...
httpd: no process found
Applying patches to Apache configs for Apache 2.4.x syntax...
Redirecting to /bin/systemctl start httpd.service
Sleeping...
NOTE: If prompted, enter the MySQL root password
NagiosQL database appears OK - continuing...
NDOUtils database appears OK - continuing...
Found config files to import - continuing...
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2016-03-07 16:44:34-- http://localhost/nagiosxi/includes/components/ccm/
Connecting to 10.116.2.248:80... connected.
Proxy request sent, awaiting response... 502 cannotconnect
2016-03-07 16:45:02 ERROR 502: cannotconnect.
NAGIOSQL LOGIN FAILED!
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './E-importnagiosql'
Nagios XI - The script that failed was: './E-importnagiosql'
rajshekar_p
Re: Nagios XI - The script that failed was: './E-importnagio
Did you configure your proxy according to our documentation?
https://support.nagios.com/kb/article.php?id=147
Make sure that you exclude localhost from proxying.
rajshekar_p
Hi lmiltchev,
Thanks a lot. The issue is solved.
I configured proxy and excluded localhost from proxying as mentioned in the link shared by you.
Regards,
Rajshekar P
Regards,
Rajshekar P
I am glad I could help!
