Hi Folks
We are using MSSQL Query option in Nagios console for Monitoring database alive state. But it expects Integer or string output from the Query. Is there any option to parse the query where-in output can be controlled with Custom message( Eg: Alert should be displayed as Database<name> is down).
MSSQL monitoring using MSSQL Query option
Re: MSSQL monitoring using MSSQL Query option
What version of Nagios are you using, and what plugin are you using? Just want to get the basic information for starters.
Former Nagios Employee.
me.
me.
i am are using nagios 5.x and default available plug-in as part of nagios installation
There are actually a couple different plugins available.chanlinux wrote:i am are using nagios 5.x and default available plug-in as part of nagios installation
Can you provide a screenshot to show us a bit more information?But it expects Integer or string output from the Query. Is there any option to parse the query where-in output can be controlled with Custom message( Eg: Alert should be displayed as Database<name> is down).
