hello,
I'm having issues changing user's access levels. When I try to change the access level of an AD user from 'Admin' to 'User', I get a red box with the message: "The confirm Password field is required".
Grtz
Willem
Change User Access Level - Confirm Password Required
Re: Change User Access Level - Confirm Password Required
Can you confirm your LS version? Your signature says said 1.4.0 but the latest is 1.4.1 - just wanna make sure so we can test the right version on our end.
Edit: I see from another LS thread of yours that you are on 1.4.1, so we'll get this tested and update the thread.
This is a bug, it also occurs when nothing is changed, I've created a bug report:
The file I need to modify is encrypted so I'm unable to provide a code fix as this point.
As a workaround:
- Edit the user
- Set the Auth Type to Local (don't save though)
- Set the Password and Confirm Password boxes to anything
- Set your Access Level
- Set the Auth Type back to Active Directory
- Click the Save User button
Thank you
NEW TASK ID 8615 created - Nagios Log Server Bug Report: Edit User > Change Access Level > Save - Confirm Password ErrorAs a workaround:
- Edit the user
Thank you
