I tried to follow the manual process which looked fine but i am still not sure if it was a successful attempt.
I didn't get the complete message that I use to get on previous upgrades, which is something like
Instead of this command line ends the update atChecking global event handlers...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
Fixing php-mcrypt bug...
Starting httpd:
No entry for terminal type "unknown";
using dumb terminal settings.
PHP Notice: Undefined index: nagiosxi in /usr/local/nagiosxi/html/includes/db.inc.php on line 483
UPGRADE COMPLETED!
If this upgrade is successful then it has not solved the issue of Upgrading NagiosXi from webinterface, although I can see the new version Nagios XI 5.2.8 on the bottom left of the page.RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1464668532.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1464668532.tar.gz
RESETTING PERMS
[root@nagiosxi nagiosxi]#
How can I be sure if it was a successful upgrade?
