nrpe nsclient++ check counter - No counters specified
zjllee
Post by zjllee »
Hi I have been trying to use the check counter function via nrpe+nsclient but I keep getting a "No counters specified: add counter=<name of counter>" unknown status in Nagios. Anyone can comment on what I am doing wrong. Here're the different ways that I have tried defining the services with no luck:
check_command check_nrpe!CheckCounter!'Counter:Idle Timer=\Processor Information(_Total)\% Idle Time' Showall MaxWarn=80 MaxCritcrit=90
check_command check_nrpe!CheckCounter!'Counter:% Processor Used Core 0=\Processor(0)\% Processor Time' ShowAll MaxWarn=80 MaxCrit=90
check_command check_nrpe!CheckCounter!'Counter=\\Print Queue(Microsoft XPS Document Writer)\\Jobs' MaxWarn=5 MaxCrit=15 ShowAll
CheckSystem is enabled on the nsclient++ agent. Thank you
Re: nrpe nsclient++ check counter - No counters specified
Can you show us the actual command run from the command line along with the output of it?
Example:
[root@localhost libexec]# ./check_nrpe -H x.x.x.x -c CheckCounter -a 'Counter:Idle Timer=\Processor Information(_Total)\% Idle Time' Showall MaxWarn=80 MaxCritcrit=90
WARNING: Idle Timer = 94|'Idle Timernone'=94;80;0
Also, show us the "check_nrpe" command definition.
Also - to add to what Ludmil mentioned, I did some testing on my end. I was seeing mixed results with single quotes, but it worked with double quotes. Could you try using double quotes?
[root@localhost libexec]# ./check_nrpe -H 192.168.5.47 -c CheckCounter -a "Counter=\\Server\\Errors Logon"
OK: \Server\Errors Logon = 0|'\Server\Errors Logonnone'=0;0;0
[root@localhost libexec]# ./check_nrpe -H 192.168.5.47 -c CheckCounter -a 'Counter=\\Server\\Errors Logon'
Failed to poll counter: PdhCollectQueryData failed: : 800007d5: No data to return.
Post by Box293 »
This article explains how the counters need to be referenced (double slashes):
https://support.nagios.com/kb/article.php?id=126
This one explains how to add a service:
https://support.nagios.com/kb/article.php?id=127
zjllee
Post by zjllee »
Thanks all!
Turns out I did not initiate the nsclient config file properly. By running nscp settings --generate --add-defaults --load-all in the nsclient install folder, I am able to set allow arguments and allow nasty characters to 1. Did the trick.
root@nagioscore:/usr/lib/nagios/plugins# ./check_nrpe -H winserver -c CheckCounter -a 'Counter:Idle Timer=\Processor Information(_Total)\% Idle Time' Showall MaxWarn=80 MaxCritcrit=90
WARNING: Idle Timer = 95|'Idle Timernone'=95;80;0
root@nagioscore:/usr/lib/nagios/plugins# ./check_nrpe -H winserver -c CheckCounter -a "Counter=\\Server\\Errors Logon"
With regards to slashes and quotes, single slashes work with single quotes, and double slashes work with double quotes.
Ah, nice find -- I had ruled out the single quotes.
Are we good to mark this as resolved?
zjllee
Post by zjllee »
lmiltchev wrote:Can you show us the actual command run from the command line along with the output of it?
Example:
Just add on, my command was defined wrongly - this was the main cause of the error as checkcounter requires the -a attribute to be defined.
Wrong
        command_name    check_nrpe
        command_line    /usr/lib/nagios/plugins/check_nrpe -H '$HOSTADDRESS$' -c '$ARG1$'
Correct
        command_line    /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a $ARG2$
This issue can be considered resolved. Thanks to all for the advice.
